Tire Pressure
Posted: Sat Dec 14, 2013 2:18 pm
by 02Bonney
I can't find the required tire pressure for my 2002 SE. My driver side door was replaced with no sticker and the manual doesn't say.
Re: Tire Pressure
Posted: Sat Dec 14, 2013 3:01 pm
by KelvinVV
Try looking at the walls of your tires. It should say something about it there, but if not, look up your tire's pressure online.
Re: Tire Pressure
Posted: Sat Dec 14, 2013 11:13 pm
by Archon
The tire wall will indicate maximum pressure at a certain load, not necessarily the recommended pressure. Fill them between 32 and 35 psi and you'll be fine.
Re: Tire Pressure
Posted: Mon Dec 16, 2013 7:14 pm
by 02Bonney
Thanks Archon, all set to 32
Re: Tire Pressure
Posted: Tue Dec 17, 2013 9:35 pm
by 1oldman
One of the daughter-in-laws has the '05 Bonneville, but IIRC its 28 PSI. I try to always run mine 32 - 35 PSI. - BC
Re: Tire Pressure
Posted: Mon Dec 23, 2013 9:26 am
by Franksdad
I run right around 35-37
Re: Tire Pressure
Posted: Sat Dec 28, 2013 12:22 am
by Night Crawler
when i have my 18" summer tires on, I run 50 psi (tires say max 55 psi), huge difference in ride then running at factory 35 psi. But stock tires usually run 30 psi to 32 psi.
Re: Tire Pressure
Posted: Sun Dec 29, 2013 2:55 pm
by MrJiggy716
I thought factory recommended PSI was 30? Am I wrong and or whats the benefit of running it higher ?
Re: Tire Pressure
Posted: Mon Dec 30, 2013 12:19 am
by nos4blood70
Running more tire pressure to a certain extent will mean better fuel economy.
Re: Tire Pressure
Posted: Mon Dec 30, 2013 1:22 am
by Night Crawler
Factory max psi is 35. But never fill to 35 since heat from friction will expand the air up to that extra 5 psi. But always read your sidewall of your tires if you are running non factory spec tires.
Re: Tire Pressure
Posted: Mon Dec 30, 2013 2:11 am
by spoiledred94
right my GoodYear Assurances run at 40 -44 as per sidewall, cold, BTW who here has any belief in the DIC tire pressure indicator?
Re: Tire Pressure
Posted: Mon Dec 30, 2013 2:20 am
by 1oldman
spoiledred94 wrote:right my GoodYear Assurances run at 40 -44 as per sidewall, cold, BTW who here has any belief in the DIC tire pressure indicator?
The DIC TPS is spot on with the wife's CTS. Can't say about the '05 Bonneville as it only reports when the TP falls to below? - I'll guess 27PSI. - BC
Re: Tire Pressure
Posted: Mon Dec 30, 2013 2:26 am
by spoiledred94
I'm 01. I expect it to be the same though. CTS is a Cadillac? There was a Caddy at the track a few years ago that was really fast. He barked the tires through four gears. Its supposed to have 550+ HP
Re: Tire Pressure
Posted: Mon Dec 30, 2013 2:32 am
by nos4blood70
My tire pressure sensor system in the DIC works perfect.
Re: Tire Pressure
Posted: Mon Dec 30, 2013 2:40 am
by spoiledred94
I haven't had any problems with the DIC either since I repaired my flat.
Re: Tire Pressure
Posted: Mon Dec 30, 2013 7:20 am
by DaMaroon
spoiledred94 wrote: BTW who here has any belief in the DIC tire pressure indicator?
My SE doesn't show pressure so can't say about that. The wheel speed sensor went off with a 1-2 pound difference on one wheel. If they all go down the same nada. It's all I need.
Re: Tire Pressure
Posted: Wed Jan 01, 2014 10:11 pm
by redzmonte
35 PSI is where mine are set. no problems, not TPMS light and wear evenly. more then that you will wear the center out faster and ride is much harsher.
S
Re: Tire Pressure
Posted: Fri Jan 03, 2014 6:30 pm
by KelvinVV
My DIC works perfectly, too. I think it just lets you know when your tire pressure gets too low, however.
