Digital climate control help????!
My 95 SSEI has digital climate controls. The display works and I can press any of the buttons and it will display on the screen but noting happen no matter what I press. No heat no air no nothing. Is this the climate controls that's not working? Because if so I've seen on at the local yard but I don't want to buy something I don't need. I've checked all the fuses inside and under the hood that may have something to do with it(I think I checked them all). Any help would be great right about now. Thanks
- haro1225
- Posts like a Northstar
- Year and Trim: 2004 GTO
Re: Digital climate control help????!
It could be the blower control module, its located under the maxi fuse box. Those usually go bad. Check the year on the one at the junkyard, as 92-94 used a different module IIRC.
Edit: Found a picture of where its located.
http://www.pontiacbonnevilleclub.com/fo ... 12616.html
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
Mine was acting up right after I bought it and surprisingly unhooking the battery for about 10 min must of rest it because its worked fine ever since . worth a shot if you haven't already tried that
