Low beam headlight works when it wants to...
Posted: Mon Nov 11, 2013 9:24 pm
by BonnieBoy08
My passenger low beam headlight started acting up about a couple weeks ago. At first I thought the bulb was out but then one night it randomly worked again. And now it hasn't lit up while driving for about a week. The bulbs aren't very old at all, I put Plasmaglow Xenon bulbs in it earlier this summer. Here's the odd part, when I lock or unlock the doors with keyless entry it lights up! (the lights blink 3 times and then stay on so you can see around the car at night) I don't know what the option is called. But when I turn the key and start the car it won't light up. Doesn't matter if I turn the switch on or just let the automatic night sensing feature do its thing. High beams work fine. Is there a module or relay in there? I'm lost.
Re: Low beam headlight works when it wants to...
Posted: Tue Nov 12, 2013 1:24 pm
by younggunls1
Lights the flash when you unlock I thought were the high beams? At least on mine they are.
I was having a similar issue but I have HID's.. They require 9-12v to properly run the ballasts and I found my light hookups are only putting out about 7.6-7.8v which Would cause issue with them coming on sometimes but doing a direct wire to the battery fixes this. I don't know if that kind of thing could cause issues with regular halogen bulbs tho.
Posted: Tue Nov 12, 2013 3:52 pm
by BonnieBoy08
I’m pretty sure it’s the low beams that flash when you lock or unlock with keyless entry. It’s the 2 inner lights and the brights are the 2 outers. Someone correct me if I’m wrong.
Posted: Tue Nov 12, 2013 6:28 pm
by younggunls1
Inner are brights
Posted: Tue Nov 12, 2013 11:38 pm
by bobgto65
I had an intermittent problem with the right low beam and it turned out to be the wiring harness from the connector to the bulb socket. I got a new harness from haro and that fixed the problem.
Posted: Wed Nov 13, 2013 9:53 am
by BonnieBoy08
younggunls1 wrote:Inner are brights
Yea you're right, checked it last night. I will have to look into it more this weekend.
Posted: Wed Nov 20, 2013 11:23 pm
by BonnieBoy08
I had an old bulb laying around I was going to try and as soon as I wiggled the connection around it lit up! That was on Sunday and so far so good. Not sure if it was a loose connection or if I have a harness going bad...time will tell.
Posted: Thu Nov 21, 2013 1:56 am
by 1tinindian
Put a little dielectric grease on the connector.
Leon
