I have 2 questions- first my ABS light and no traction light "occasionally" come on, any ideas why?
2nd question- I replaced both the sepentine belts about 2 weeks ago and now I am getting a squeal, although I don't think it's from a slipping belt, it does get quieter when it warms up but if you accelerate it will squeal again. Maybe a pulley?? any ideas again?
ABS Light,etc
- trkelly
- Year and Trim: 1997 40th Anniversary SSEi Supercharged
ABS Light,etc
1997 40th Anniversary SSEi Supercharged "Dark Cherry Metallic"
222,600 KM (141,000 miles)
J-ROD
- SSEi Member
- Year and Trim: 2012 Chevy Silverado Z-71 LTZ
Re: ABS Light,etc
Check and/or clean your wheel speed sensors at each corner of the car. Look at the connection and the sensor itself for damage. It sounds like it may just be a short in the wiring harness. A freind of mine with a '99 G.P. had the same issue after he had accedintally broken one of his speed sensors, and his traction control & ABS light came one. He replaced the sensor and all is well now.
Jarod S Fisher
2009 Chevy Impala LTZ
- Echo SSEI
- Retired Gearhead
- Year and Trim: 1997 SSEi
1993 SSE - Location: Phoenix, Arizona WCBF '05, '06, '07, '08 - NEBF '07
Re: ABS Light,etc
When do they "occasionally" come on? Any common times or conditions when this happens?
"Really Not Stock Anymore" Bob and most recently renamed, "Chief BadLifter"
Best ¼ ET=13.674, Best 60’=2.122, Best Trap=102.26 mph Pacesetter headers (2.5" outlet), Magnaflow hi-flo cat, INTENSE FWI w/K&N 9" cone, ZZP XP cam, INTENSE OR pushrods, Comp 105 springs, Autolite 103 plugs, Stoppenbach tuned PCM
SingsCountry1967 wrote:I can babysit your car for the week... or rent it.... I won't race it I swear <fingers crossed>
freneticburn
- Posts like an LN3
- Year and Trim: 1998 Bonneville SE?
Re: ABS Light,etc
I agree. If your car is anything like my 98 SE the sensors have plugs for both front left and right on the side walls inside the engine compartment. The passenger side one is pretty exposed, and right next to your belt so maybe you bumped it and damaged that one. The other one is straight across on the driver side.J-ROD wrote:Check and/or clean your wheel speed sensors at each corner of the car. Look at the connection and the sensor itself for damage. It sounds like it may just be a short in the wiring harness. A freind of mine with a '99 G.P. had the same issue after he had accedintally broken one of his speed sensors, and his traction control & ABS light came one. He replaced the sensor and all is well now.
I'd carefully inspect that passenger side one though since you said something about changing your belt.
- trkelly
Re: ABS Light,etc
there is no common time the no traction and ABS lights coming on, they come on when I'm driving and not applying the brakes, if I shut off the car and restart they are sometimes off and sometimes they are still on.
I'm going to have to check out the speed wheel sensors, that seams like a good place to start.
Any thoughts on the squeaky pulley's, maybe a bad tensioner?
