increasing knock retard
Posted: Thu Oct 10, 2013 7:14 pm
by parkaveman83
What can cause knock retard to start increasing. Used to only get 2-3deg when it was shifting and 0 when I'd get wide open. Now its hitting 5-6 pretty regularly wide open. And usually as soon as it gets into boost its starts 1-2deg of knock retard. Its gettibg cooler outside and its only getting worse. Basicly stock car with 128, 000 miles. Gonna dchange the fuel filter soon.. but it doesn't run any diff cold. And pulls just ashard as it did when I bought it.
Re: increasing knock retard
Posted: Thu Oct 10, 2013 10:02 pm
by Zeik75
Motor mounts possibly, specifically the front trans mount. Thats my first guess and should be easy to check.
Posted: Fri Oct 11, 2013 1:05 am
by parkaveman83
Hadnt really thought about that. Could the supercharger coupler cause it when its running? I think I hear the rattle whenu shut the motor off that means it's starting get bad.
Posted: Fri Oct 11, 2013 10:48 am
What else have you done for maintenance? Have you seen my list?
http://www.pontiacbonnevilleclub.com/fo ... 40156.html
Posted: Fri Oct 11, 2013 10:57 am
by redzmonte
cold air=Dense air.. more air, more KR. could just be getting leaner with the colder air.
S
Posted: Fri Oct 11, 2013 2:11 pm
by yourgrandma
Hot air causes knock. Plugged air filters don't help any, old plugs, different fuel, (remember, winter blend is coming), malfunctioning sensors...
Posted: Fri Oct 11, 2013 2:37 pm
by SSEimatt93
I've had this issue for a while. I sprayed some brake cleaner at the EGR stove pipe, under the Throttle Body and found a good sized vacuum leak, which will cause KR. Replaced it when a new one from GM, problem solved.
Brake cleaner will help you determine if you have any vac leaks, get the stuff that does not leave a white residue if you want to try this. CRC in the green can works good.
Posted: Fri Oct 11, 2013 8:43 pm
by parkaveman83
The maintenance has prob not been great on this car. I've only had it for about 6000miles. I've done the oil and new air filter and gutted the air box when I did it. I'm gonna change the fuel filter soon. And try to throw plugs and wires at it and see what that does. It has 128, 000 miles on it. And doesn't seem like much of anything got changed on it before I got it. I have been running 93 in it except for a tank 5 fillups ago. I think I put 87 in it by acident. Trying to meet my wife at the er at 1am and I wasn't thinking to clearly. After that it the knock never went back to where it was. It did go down from 8-9 to 5-7 it does now.
Posted: Fri Oct 11, 2013 8:47 pm
by parkaveman83
00Beast wrote:What else have you done for maintenance? Have you seen my list?
The ngk plugs u have listed, are they the cooler range spark plugs than what the fact had put in them?
Posted: Fri Oct 11, 2013 11:28 pm
605's are 1 step colder, TR55's are stock heat range. Autolite 104's are 2 steps colder.
Posted: Mon Oct 14, 2013 10:31 am
by parkaveman83
Is it possible that the cat is starting to clog up some? When I first got it it would only get up to about 7.5-7.7 into boost in first gear. Now its getting more like 8.5 in first wot. I know the exhaust around the motor sucks on these cars. Just didn't know how much the cat played into that
