speakers
1997SEgreenmonster
Year and Trim: 2003 BONNEVILLE SE
speakers
Post by 1997SEgreenmonster »
My passenger side door speaker isnt working do i have to take apart the whole door to pull that speak out
Re: speakers
Yes. You have to remove the door panel to remove the speaker.
bobgto65
2004 Bonneville GXP
Re: speakers
Post by bobgto65 »
It may not be the speaker. It is possible that one channel went our in your radio. But if you hear something out of the tweeter in the door and not the larger speaker, then the speaker is bad. If yo hear nothing out of either then it could be the radio or wiring.
bobgto65
Dean
Year and Trim: 2000 SE
Re: speakers
Post by Dean »
Door cladding is not that hard to pull off though. Make sure you distribute the pressure (i.e. use a wide, flat object) when you are prying it off. I don't think there are any bolt or screw fasteners - they are all clips that make an awful "plastic snapping" noise to make you think you've broken something. You haven't. Just go slow and pry open the driver handle when you get to that point.
2000 Dark Bronzemist Pontiac Bonneville SE 3800 Series II L36
1998 Bright Arctic White Chevrolet Lumina LS 3100 Generation III L82
Re: speakers
Be careful though cause those clips breaks super easy.
Tekara
Re: speakers
Post by Tekara »
2000 Bonneville SE - Gen V TopSwap
- Fenderwell intake, N* Throttlebody, LQ4 MAF sensor, 3.4 Modular Pulley, Stage 2 Intercooler, 60# injectors, 1.9 Roller Rockers, Custom Tune
- DIY CarPC w/ Centrafuse frontend, Image Dynamics IDQ12 v.3 Sub / X69 Midbass rear / CXS62 V.2 Components front
redzmonte
Year and Trim: 2000 SSEI
Re: speakers
Post by redzmonte »
Oriley Auto parts had the clips instock as a kit. couple longer ones couple shorter ones. yes you need to take the pannels off. the speaker IIRC is connected to the pannel.
S
Shane "RedZMonte"
2004 Z16 Z06: Virgin
