Lights out!! **Solved**
Sacaledus
Year and Trim: Back on deck... White 94 SSEi..
Post by Sacaledus »
So the fuse for my lights keeps blowing. Courtesy lights, Dash lights, no tail lights but Brake lights work. Blinkers work when turned on, reverse lights up. Need to know where to start folks! :helpsmilie:
Back on deck with a 94 SSEi... 294K and counting!Image
mefloump
Year and Trim: 2001 SLE
Re: Lights out!!
Post by mefloump »
I don't recall where the cigarette lighter is on these year cars or if they have ashtrays, but if they do, make sure a coin or some other metal didn't fall down in the socket. It will cause the issue you are having.
'01 Bonneville SLE
'93 Grand Prix SE Coupe 3.4L Twin dual overhead cam
motopsyco
Year and Trim: 1992 SE
Re: Lights out!!
Post by motopsyco »
they have ashtrays and lighter in the very front of the center console, but i dont think these years have the lighter tied into the lights fuse. I would have to say to remove your tailights and check if the housings have bad seals wich leak water int the lights, and corrode the sockets, mine did that. most likely with the tailights, but mine didnt blow a fuse though. Although its a definate possibility.
Sacaledus
Re: Lights out!!
Post by Sacaledus »
Have a leaky tail light housing that had rusted the connectors in the bulb socket. cleared out the water drilled a weep hole and replaced the socket and she's just fine!
Bob Dillon
Re: Lights out!!
Post by Bob Dillon »
Excellent. Now please edit the title of this post with "solved" at the end so others searching in the future will have an easier time.
