door to fuel tank
- pete25
- Year and Trim: 2003 Pontiac Bonneville SSEi
door to fuel tank
The door to the fuel tank has locked and can't get it open. I tried locking and unlocking car and that did nothing. Then i looked around and couldnt find any override button or something like that.
bonnevillain
- Year and Trim: 2002 SLE
Re: door to fuel tank
there is a release in the trunk, on the drivers side behind the carpet
- pete25
Found it. I guess I overlooked it at the gas station thinking it was a trunk release because it was covered in tape. It still latches shut everytime I close but at least now I have a way to open it.
bonnevillain
funny story... while looking for my water leak, i got in my trunk with a flashlight and had my dad run a hose over the outside of the trunk to find where it was coming in, and once i found it, i pulled on that lever for a minute or so before i realized it wasn't the trunk release!
- pete25
Yea, i figured that was the mob victim cord. But i peeled back the tape and it said fuel door or something like that.
billberry12
- SSE Member
- Year and Trim: 2001 SE 130,000 miles.
Mine never opens unless I open the trunk and pull that release wire. Any idea why it won't open otherwise, even though this is probably good with gas being $4.00?
2001 SE
130,000 miles. All but 11,000 are mine.
Want to drive it another 130,000! Any tips are welcome.
- pete25
well first thing that came to mind when it happened was the commercial where the car won't let the guy fill up with gas because it's not a certain chain gas station.
00SLE
- Year and Trim: 2000 Bonneville SLE, Black
Mine did that too. I just unplugged the lock mechanism so the door stays unlocked all the time and put a locking gas cap on instead. Not ideal, but it was a quick fix.
Peej9089
- Year and Trim: 2000 SLE Bright White
Just bend the bracket that the locking mechanism fits into very slightly and it will work fine. Had the same problem and thats how I fixed it. Works good now/
Rusgreim
- GXP Member
- Year and Trim: White 2000 Bonneville SLE
In addition to bending the bracket a bit, you might also consider disassembling the locking mech and using a little lubrication.
Russell (Rus or Rusty)
White 2000 SLE - 161k Miles
Current Mods - Transgo Shift Kit, 180* Drilled Thermostat, NGK TR55 & Belden Plug Wires, Suspension Energy Endlink Upgrade, "Stock" 12-Way Power Seats, "Stock" Heated Seats, "Stock" Homelink GDO, Cleared Corners, Pins & Dealer Badge Removed, 2002 56I Center Console, Dash Trim, Steering Wheel and Shifter Swap, Auto-Dimming RV Mirror, Pioneer AVH-P4000DVD MP3/USB Headunit w/ Steering Wheel Controls and iPhone Music Interface, Hood Protector, Gutted Airbox w/ K&N Filter.
Mods in Progress - SSEi Inflator with Stock controls, Chrome "Swoopies" (Have rims, need tires)
Future Mods - Viper 5701 Remote Start with Smart Start and 35% Window Tinting
