cylinder 4 misfire
Posted: Sun May 26, 2013 6:47 pm
by Bonneville'n
I've changed plugs, wires, and coil pack...still getting the code. What else could cause it?
Re: cylinder 4 misfire
Posted: Sun May 26, 2013 7:31 pm
by justin85
have you tried moving coils around to see if the misfire moves? if doesn't move and is still misfire on #4 then I would suggest to replace the ICM. ( the plate that the coils sit on)
Posted: Sun May 26, 2013 10:53 pm
by loudog1972
I had a misfire on 6 turned out to be an intermittent fuel injector. While in idle it has a slight stumble. However step on it, the stumble was horrible. Felt as if the tranny was falling off.
Posted: Mon May 27, 2013 12:01 pm
by Bonneville'n
I've changed the coil pack on cylinder 4, I think I changed the plate under the coils not that long ago. I sometimes have a stumble at idle, I've been getting worse mileage by 2-3 mpg. Sometimes feels like it's not making the power it should.I've been thinking of changing the injectors. Any advice on where and what to get?
