traction control button
Posted: Thu May 16, 2013 11:25 am
by david
I have a 2000 Sle and was wondering if the TCB on the console go up and down? The one in my car that I bought the girl spilled everything and anything everywhere so the button does not move.The light gos on but I cant get it to go off. Thank to all Dave
Re: traction control button
Posted: Thu May 16, 2013 11:29 am
by gweg_b
Mine was the same way when I bought my Bonneville. I just lifted the cover that sits over the shifter, unplugged the button and popped it out of the cover.
I then cleaned it with lots of rubbing alcohol, let it dry out for about an hour, put it back in, and the button was working again.
Posted: Fri May 17, 2013 1:15 pm
Yes, you're supposed to be able to depress the button to disable TC. I agree, you can try cleaning it with alcohol or something, or get a good one from harofreak00.
Posted: Fri May 17, 2013 4:31 pm
by nubuilder
It doesn't just push out the bottom though. There is a small torx T15 or T10 screw holding it in place on the back side.
Posted: Sat May 18, 2013 10:27 am
by bobjones003
I need to do this to one hvac controls on my car
Posted: Sun May 19, 2013 2:43 pm
by david
thanks to all
Posted: Sun May 19, 2013 6:37 pm
by david
the girl spilled so much junk I had to pull the switch apart just to clean it. How do you spill stuff and just leave it???? At one point I thought it was alive. It reminds me of cleaning my daughters car,its like really could we get anymore junk all over the car.Hope the switch still works.
Posted: Mon May 20, 2013 10:45 pm
by nos4blood70
If it doesn't work at least it's a cheap and easy replacement.
I'm glad the 02+ put the TC and heated seat switches in a much smarter place..
Posted: Wed May 29, 2013 8:47 pm
by david
Had to remove shift handle to pull it out.Sprayed it down and took it apart and it works.Why put a switch right below a cup holder,rocket scientist I tell you.
Posted: Wed Jun 05, 2013 11:20 am
by sandrock
I can see it. Where the TC and the heated seat switches are in 2000 and 01 models, they are easy to reach, which is what the engineers were aiming for. Personally I like them there just for that reason, but I like the cupholders in my '05 GXP...which moves the switches up under the center stack.
