Page 1 of 2
ZZP Air intake
Posted: Mon Apr 29, 2013 7:01 pm
by terrancew3
I saw this on their website:
http://shop.zzperformance.com/store/p/6 ... ntake.aspx How hard do you think this would be to install in to a Bonneville? It says it can be modified, but what do you have to mod?
Re: ZZP Air intake
Posted: Mon Apr 29, 2013 11:12 pm
by nos4blood70
It wouldn't seal correctly behind the headlight as the headlight structure and shape is different, so it would almost be a hot air intake. Why not get the INTENSE tried and true method? Or if you are concerned with looks, try this...
http://www.wbodystore.com/air-induction ... stem-.html
You can get it in just about any color or finish. And for cheaper than the ZZP.
Re: ZZP Air intake
Posted: Mon Apr 29, 2013 11:39 pm
by terrancew3
I really want something that has a box around the cone rather than the fender well. Idk how good my fender well is sealed from water, so my luck I'd suck up water and screw up my engine with a fender well intake. Is the Intense CAI a box one, or a FWI too?
Re: ZZP Air intake
Posted: Tue Apr 30, 2013 12:11 am
by haro1225
The INTENSE one is one of the better ways to go, I've had it on 2 cars, for at least 3 years, and never had any issues. As long as you don't drive down a massively flooded road, the water won't get in there.
Re: ZZP Air intake
Posted: Tue Apr 30, 2013 9:07 am
by nos4blood70
I drove into a puddle that submerged half my cone, nothing happened. You'll be fine.
Re: ZZP Air intake
Posted: Tue Apr 30, 2013 6:06 pm
by terrancew3
Well I got an email back from ZZP and this is what they said: "There is a slight gap at the radiator support, and you can just use self tapping screws to attach the lower section. Other than that, it fits pretty well."
Re: ZZP Air intake
Posted: Tue Apr 30, 2013 7:24 pm
That's BS. I know of at least one member who bought one to try, and it was just different. There's a reason 90% of us run FWI's. They work.
Re: ZZP Air intake
Posted: Tue Apr 30, 2013 7:27 pm
by terrancew3
On a scale from 1 to 10, how hard is it to install one of these FWI's then? 1 being simple, and 10 being really hard.
Re: ZZP Air intake
Posted: Tue Apr 30, 2013 7:33 pm
Sirius wrote:On a scale of 1 to 5 where
1 = What’s a wrench?
1.5 = I’ve seen a wrench before.
2 = Got me some tools!
2.5 = Got me some tools, and I ain’t afraid ta use ‘em.
3 = Decent mechanic, but some things scare me.
3.5 = Good mechanic – ain’t skeert.
4 = Highly skilled in the mechanical arts.
4.5 = Mechanical wizard.
5 = Automotive god…don’t try this at home.
On that scale it's a 2 or so. Very easy with basic hand-tools. There are several great write-ups around about it. Just search FWI and you'll find a lot of good info.
Re: ZZP Air intake
Posted: Tue Apr 30, 2013 7:44 pm
by terrancew3
Okay. As for the IAT, can that be extended as well, or will the molded hole have to work?
Re: ZZP Air intake
Posted: Tue Apr 30, 2013 8:01 pm
by Jfridge92
You can extend it with a harness. I have mine extended into the well on my car right beside the cone filter. I have the IAT shoved into a PCV breather so it's protected from the elements. I took off the coupler that has the IAT bung in it and bolted the tubing right on my throttle body.
Re: ZZP Air intake
Posted: Tue Apr 30, 2013 10:04 pm
by nubuilder
I didn't have to extend my IAT. I just put it so it was a little more towards the back of the piping. I didn't go far, only about 1in back from straight up. I don't think it will impact temps from the exhaust.
forum/performance-brainstorming/topic234.html
Installation is a breeze. I think you need a flat screwdriver, a ratchet, and a couple sockets (plus stuff for removing the tire). The most difficult part is marking and drilling pilot holes for the bolts for the PCM tray. Well, the only other hard part is if your wheel is rusted on like mine was....but I'm not counting that.
Re: ZZP Air intake
Posted: Tue Apr 30, 2013 11:41 pm
by terrancew3
Jfridge92 wrote:You can extend it with a harness. I have mine extended into the well on my car right beside the cone filter. I have the IAT shoved into a PCV breather so it's protected from the elements. I took off the coupler that has the IAT bung in it and bolted the tubing right on my throttle body.
Does this make it noticeably different or is it just for precaution kind of stuff
Re: ZZP Air intake
Posted: Wed May 01, 2013 10:38 am
by gweg_b
I did mine in about an hour, around 5 years ago. Keep in mind, the me 5 years ago could barely take a throttle body off.
Now, I didn't drill any holes for the PCM tray (used the power of zip ties). I know, not the best method, but the me of today still isn't very good with power tools (almost cutting a finger off keeps me and power tools on a non-speaking basis).
I also have the extended IAT harness, but have yet to actually do anything with it yet. The IAT on mine is still in the location provided by the Intense coupler. I was going to put mine somewhere in the pipe, but I actually like Joe's idea.
Re: ZZP Air intake
Posted: Wed May 01, 2013 11:32 am
by 2003 SSEi
here is the Intense FWI
Whats in the box
PCM Tray
Coupler where your IAT goes
In the Bumper
the final product
Re: ZZP Air intake
Posted: Thu May 02, 2013 7:47 pm
by terrancew3
2003 SSEi wrote:here is the Intense FWI
Theres nothing there, lol.
Re: ZZP Air intake
Posted: Tue May 07, 2013 4:07 pm
by ytd1861
I bought one of the FWI systems from Intense just a few weeks ago. Today I took it off my car and sent it back for a refund. It was louder than I like. For $179 I felt the funds could go to other performance mods. However, it seemed to help (some), but in my opinion not $179 worth!
I followed procedures on this site and gutted my stock airbox and it seemed to provide just as good results, but way cheaper! I'm not trying to sway you, its your money and time, and it is pretty easy to install if you can at least snap a socket on a ratchet. Best of luck to you and I hope it performs the way you want.
Re: ZZP Air intake
Posted: Tue May 07, 2013 6:20 pm
by Alpine_jake
DONT BUY THE ZZP INTAKE!!!!!!!!!!! I GOT ONE HAD IT HALF CUT APART BEFORE I DECIDED TO SAY SCREW IT AND THROW IT AWAY. IF YOU BOUGHT IT SEND IT BACK ASAP
Re: ZZP Air intake
by Alpine_jake
Re: ZZP Air intake
Posted: Tue May 07, 2013 10:00 pm
by terrancew3
ytd1861 wrote:I bought one of the FWI systems from Intense just a few weeks ago. Today I took it off my car and sent it back for a refund. It was louder than I like. For $179 I felt the funds could go to other performance mods. However, it seemed to help (some), but in my opinion not $179 worth!
I don't know what I want to do. I'm not really too keen on tearing up my air box and if I want to sell it they my question me as to why its like that.
