I got some NGK TR6's, 1 step cooler than the TR55's. They were a second choice, but im a little pressed for time at the moment. Should I gap to factory, for the S2, or something based on mods. Basically headers, cat delete, gutted box (temp) 180 stat, and a 3.4. I also have 94 octane here.
Cheers
Gapping cooler plugs in prep for pulley drop
- Backhoe
- Posts like an L27
- Year and Trim: '98 LSS L67
1998 Olds LSS/L67, 92K miles, Intense FWI, SSAC headers, 3.2 MPS, cat delete, 180 stat, AL 103's, HPT.
1996 Olds Eighty Eight LS/L36, 146K miles, mostly stock
1997 Olds LSS/L36, 95K miles, raided for dent free parts and sold
1989 Bonneville LE Gem (sold)
1987 Bonneville LE (retired)
- mylittleblackbird
- Posts like a Northstar
- Year and Trim: 1995 LX(went to the shredder)*sniffle*
1999 SE - Location: Muscatine, IA
Re: Gapping cooler plugs in prep for pulley drop
I don't recall what the factory gap calls for, but I always run my plugs a .060" on my coil pack equipped vehicles. However, the temp of the plug will not have a bearing on the gap you use. The actual difference comes in with how much heat the plug aids in removing from the cylinder. So whatever you happened to use before should be fine.
Of course, I'm open to being corrected.
I have a Bonneville, it's white and N/A!
Mod List: Hood and Fender "adjustment" - "Enhanced" A/C compressor clutch - Extra loud PS Pump - Mega sensitive CKPS - Audible Rear Drums - Lowered headliner - Custom stained upholstery - "Brown Devil" weight reduction kit - Low Friction Belt. More to come!
- Backhoe
- Posts like an L27
Maybe I'll go out and finish the fronts, and do the rear after I check back here on the topic.
Thanks
Thanks
gap to stock.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
I agree, stock .060". There is no benefit/loss to a smaller gap, unless you're running high boost or nitrous.
- Backhoe
- Posts like an L27
Done! Cylinder #1 was actually the worst of the lot with the fans swapped to opposite sides.redzmonte wrote:gap to stock.
Ready to gas up on 94 and head up-island, thanks guys.
