offset rear suspension?
TheMannn
Year and Trim: 2001 Pontiac Bonneville SLE
Post by TheMannn »
Thought i might ask before i go measuring and checking wheels... does these cars (2001 SLE) set off to one side in the rear? I noticed my left rear tire was in farther than the right side. I have the slanted 5 star factory wheels, not original. maybe some had different offsets? Thanks!
Re: offset rear suspension?
No, it should be symmetrical, and all the bent-5 spoke wheels were the same.
Sounds like something is bent.
nubuilder
Post by nubuilder »
Check your toe links. They run from the lower control arm, up to the center of the car. This shouldn't bring the entire wheel in farther though, just tweak it. I would also look at your control arm mounting points.
It turns out my car had one that was bent and I didn't know it until I replaced it. Not sure if that will affect my alignment when it is done or not.
Matthew
1998 Chevy K1500 Silverado Z71 ECSB L31 -- project/toy
1998 Chevy S10 ZR2 ECSB L35 5spd -- winter truck
2002 Pontiac Bonneville SSEi -- stock (trying to keep it that way...we'll see...)
