Almost no boost, code PO243
Posted: Tue Apr 16, 2013 5:06 pm
by spacelucky17
So one running issue is solved and a new scan reveals this code, which is listed as 'Supercharger Boost Selonoid Control Circuit'. Ive also lost pretty much all boost in the past week
Help!
Re: Almost no boost, code PO243
Posted: Tue Apr 16, 2013 11:02 pm
by Archon
The most likely cause is a bad boost control solenoid.
Posted: Wed Apr 17, 2013 10:46 am
by spacelucky17
Ok, so I've tracked down a way to diagnose that (love google lol). Now is that a part that can be replaced on its own or is it something bigger like the whole supercharger that will have to be done?
Posted: Wed Apr 17, 2013 11:14 am
by 2003 SSEi
The Part circled yellow is the Boost Controll Valve
The Part circled blue is the Solenoid
Posted: Wed Apr 17, 2013 12:27 pm
by spacelucky17
So how would I go about ordering a replacement? Is a used one ok?
Posted: Wed Apr 17, 2013 12:44 pm
by 2003 SSEi
used is fine, Contact Harofreak00
Posted: Wed Apr 17, 2013 1:41 pm
by spacelucky17
Thanks!
Posted: Fri Apr 19, 2013 3:20 pm
by Rogue
You might also check to see if you blew the vac line off the port under the supercharger snout.
Posted: Fri Apr 19, 2013 8:20 pm
by redzmonte
Rock auto has one for $26 new.. chose your car and search under engine/Supercharger Bypass Solenoid
STANDARD MOTOR PRODUCTS Part # U44001
Posted: Sat Apr 20, 2013 9:30 am
by spacelucky17
Awesome thanks so much!
