Low Coolant Indicator Level
samples08
88,000k
Post by samples08 »
How do i find out weather or not my radiator has a low coolant sensor?
Member #3848
2002 Black Bonneville SE Sold But Not Forgotten
2002 White Bonneville SSEi Project car
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Re: Low Coolant Indicator Level
Post by 2003 SSEi »
it does.
You sure about that Pat? I thought only the GXP's had coolant level sensors. I know for a fact that the SLE/SSEi's dont. I haven't parted out any SE's though.
I don't think you have one, but on my aftermarket radiator there's a hole I had to plug for the sensor if it were equipped that was behind the passenger headlight.
2003 SSEi
LOTS of Mods
Post by 2003 SSEi »
I thought that there is a light on the SE dash for Low Coolant....maybe im thinking Grand Prix...
Ya must be Grand Prix.
Travis, if you need to know, just go and look at your radiator. If it has an electrical plug going to it, then you do... but I doubt you do. The aftermarket ones come with a hole for them, but you can leave that hole plugged.
samples08
88,000k
Post by samples08 »
Thanks andrew i got to thinking last night and didnt remeber seeing any dummy light come on all those times i had low coolant but i wanted to double check but i didnt see one
Member #3848
flatlander745
Post by flatlander745 »
Spectra radiators have with and without sensor port. I just ordered one w/o for my '00
2000 SSEi Galaxy Silver with New TEP Trans, A 62,000 mile engine out of grandma's car, all new front and rear suspension KYB/ Energy Suspension.
[url][URL=http://s871.photobucket.com/user/flatlander745/media/image-5.jpg.html][IMG]http://i871.photobucket.com/albums/ab278/flatlander745/image-5.jpg[/IMG][/URL][/url]
DaMaroon
Year and Trim: 2003 SE
Post by DaMaroon »
Geeze! Sure thought it would but then remembered not seeing it when test driving the car and it was low due to intake leak. 96 G Am SE had one in the recovery tank. Guess they got tired of people complaining about the light when their intakes started leaking. :evil:
1oldman
Post by 1oldman »
harofreak00 wrote:You sure about that Pat? I thought only the GXP's had coolant level sensors. I know for a fact that the SLE/SSEi's dont. I haven't parted out any SE's though.
hmmmmmmmm '92 SSE & SSEi all have low coolant sensors. only the SE doesn't, at least the few I've seen. - BC
sandrock
Post by sandrock »
We're talking 2k-up here. The pre-2k models did have a low coolant sensor if you were SSE/SSEi. Starting in 2000, none of them came with it, then in 2004 the GXP included it for one reason or another.
Arrowhead
2005 GXP
Post by Arrowhead »
My low coolant sensor has started giving a constant false warning in an 05 GXP, apparently it's a common problem that the only fix is to put a completely new reservoir in. It sure seems like Mr. Goodwrench really likes keeping us bent over his bench ! I may just research a disable route for this irritation. :banghead:
97ParkAve
Year and Trim: 1997 Park Avenue (Base)
1986 Ford Mustang GT
Post by 97ParkAve »
My 1997 PA with the NA 3800 has a low coolant sensor. Ive seen it in action before ;) before I replaced the black plastic elbows with the metal ones.
