Sudden MPG Drop
tizom34
Sudden MPG Drop
Post by tizom34 »
Hi Guys & Gals,
I have a 2002 SE with 210,000 miles and have owned it since it had 50,000 miles on it. This car has always always always averaged 28-30mpg. However, about 6 months ago every tank began averaging 18-20mpg, hand calculated of course, and continues to be that way. Car is throwing no codes, I have checked MAP, MAF, EGR, and plugs and wires were replaced at 200,000, and everything appears to be up to snuff. For the most part the car runs as normal; the only non-normal indication is that under slightly harder than normal acceleration from a rolling start it will bog down slightly. I am looking for any advice on what you think may be causing this?
Thanks
redzmonte
Year and Trim: 2000 SSEI
Re: Sudden MPG Drop
Post by redzmonte »
Tuneup items (plugs, wires ect)
Dirty MAF
Vac Leak
are the things i would investigate 1st. do you have a scanner of any sort? your LTFT's will tell you alot, should see +/- 2-3%.. anything over that will indicate a issue.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
Re: Sudden MPG Drop
Almost sounds like a plugged cat...
Re: Sudden MPG Drop
00Beast wrote:Almost sounds like a plugged cat...
That's what I was gonna say.
mdrew
Year and Trim: 2001 SSEI
Re: Sudden MPG Drop
Post by mdrew »
maybe clogged fuel injectors or fuel filter. I guess that could be covered in the above "tune up items"
tizom34
Re: Sudden MPG Drop
Post by tizom34 »
Alright thanks guys I'm gonna check out all of the above
skregal
Year and Trim: 95 SSEi
05 GXP
Re: Sudden MPG Drop
Post by skregal »
Check your tire pressure. The warning won't come on the dash
if they are all around the same lowness (word?) in pressure.
That shouldn't have happened suddenly however, unless a huge weather change
or something.
