01 ssei steering problem NEED HELP !!
J.G
Year and Trim: 2001 ssei S.CH
Post by J.G »
Driving back from work the power steering system on my 01 bonne ssei failed . I can only turn right with NO problem but when turning left the wheel gets hard , there is NO noise and the power steering fluid is at the normal level and also clean. ANY IDEAS WHAT COULD BE>>>>
Re: 01 ssei steering problem NEED HELP !!
Probably a bad steering rack, you'll need to replace it.
SPLLOUDER
Year and Trim: 2001 BONNEVILLE SLE
Post by SPLLOUDER »
Most likely the rack like haro said . make sure there is nothing wedged up there , and your tie rod end is intact .
2001 BONNEVILLE SLE (Galaxy Silver)
2002 BONNEVILLE SE (Galaxy Silver) (DD)
deano55
Post by deano55 »
How many miles on the car?
