I purchased an El-Cheapo Pre-cat O2 sensor on eBay when I started getting the P0134 code on the original sensor. It lasted probably 3 days and the code came back. I drove it like that all summer until I finally had enough of resetting the SES light. After doing some research, I learned that the Denso is the sensor of choice, so off to Rock Auto I went.
Fast Forward to this morning.... I fixed the P0134 code just like that (making snap sound with fingers...) with the install of the good quality sensor.
Now, I'm getting a code P0420. The cat is probably 2 years old with maybe 18K on it. I did replace the rear sensor back in the spring, before I started getting trouble codes on the front sensor. I'm pretty sure it's a.......Bosch
I know, I know... But I didn't know then. So just to verify, I'm fairly confident that the rear Bosch sensor is acting up trying to communicate with the Denso pre cat sensor...
Time for another Denso for the rear sensor.....
Your thoughts????
