Front end shaky under acceleration ? (2000 SLE Red Violet )
SPLLOUDER
Year and Trim: 2001 BONNEVILLE SLE
Post by SPLLOUDER »
I Finally got this car all legal to driver and put 25 miles on her today . Overall Drove Great !
Only thing i cant really figure out is the shaky front end at times ?
Symptoms :
-Shifting out of park and into R or D slight Clunk and jerking of the car .
- at 60-70 mph coasting , very slight vibration consent with steering wheel rocking back and forth with vibration .
- Under load at highway speed and accelerate 3-5 k RPM it shakes the whole car slightly in a weird vibration ?
What does this sound like ? Kept in Mine the tires are all matching and almost Brand new .
( p.s. front left tire is started to get a lot outside tread wear faster compare to other tire's .)
2001 BONNEVILLE SLE (Galaxy Silver)
2002 BONNEVILLE SE (Galaxy Silver) (DD)
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Re: Front end shaky under acceleration ? (2000 SLE Red Viole
Post by 01bonneSC »
Did you have an alignment when you got the tires?
FiendScurro
Post by FiendScurro »
Transmission needs something I forgot what but saw same symptoms in another post.
Shaking steering wheel should either be bad tie rod or control arm not sure which happens at higher speeds
And uneven tire ware could mean alignment issue as previously stated.
Dan
Scurro
SPLLOUDER
Post by SPLLOUDER »
will the front transmission mount cause this ?
I don't know if it was aligned when these tire where put on about 9 months ago . i bought the car like this .
SPLLOUDER
Post by SPLLOUDER »
what else would cause this ? Motor mount ? Trans Mount ? CV Half shafts ?
where should i look first ?
Sounds like you could use an alignment and a solid front mount.
SPLLOUDER
Post by SPLLOUDER »
nos4blood70 wrote:Sounds like you could use an alignment and a solid front mount.
Thanks because this is what i was thinking too.
SPLLOUDER
Post by SPLLOUDER »
I detailed the car yesterday , and checked the air pressure in the tires for first time .
Front right tire had 48 PSI in it :bluetwitch:
left front had 22 psi :bluetwitch:
So, I put 35 PSI all around , and now car pulls to right slighty now .
and i got it up to 65 on a 40 MPH road :evil:
and the shaking is allot less noticeable but still kinda there .
So , I'm just gonna get the tires re balanced , rotated , and get a 4 wheel alignment , and go from there .
firstbonnei1994
Post by firstbonnei1994 »
My sle would jerk when shifting to D or R. Also it would vibrate when going 50-55mph. After changing one of the ignition coils that was bad, it has been fine since then.
Zeik75
Year and Trim: 1988 LE
Post by Zeik75 »
The jerk when shifting could be from a motor mount for sure. Does it slam or knock when shifting under power?
-Austin-
terrancew3
Year and Trim: 2009 G8 GXP
Post by terrancew3 »
Zeik75 wrote:The jerk when shifting could be from a motor mount for sure. Does it slam or knock when shifting under power?
I had my front one replaced recently, and I still get a slight jerk when shifting from park to R or D. Could this mean I also have other mounts that are junk?
2000 SSEi *sold 9/27/15* December '12 & May '15 COTM
2005 Grand Prix
2009 G8 GXP #418 of 1,829 November '15 TOCOTM
Zeik75
Post by Zeik75 »
Well they are 12 years old, so there is no reason they couldn't be going bad
-Austin-
terrancew3
I checkd under my car yesterday, and found that the other 3 mounts look just fine. I am sure they aren't as sturdy as they once were, but there isn't any crack or tears in them.
2005 Grand Prix
