time for a thermostat
wader2k
Year and Trim: 2002 Bonneville SLE
Post by wader2k »
Driving home tonite on the highway the Service Engine light came on and stayed on.
It's been colder lately and the engine hadn't been heating up all the way, so I figured the thermostat was sticking partially open.
Pulled the codes at Autozone and sure enough it was a P0128- coolant temp always low.
Never been so happy after pulling a code <grin>.
So how much antifreeze will leak out if just pull the thermostat housing without draining any? I read somewhere up to a 1/2 gallon, but that doesn't seem right.
RJolly87
Re: time for a thermostat
Post by RJolly87 »
1/2 gallon sounds right. Everything in the cooling system higher than the thermostat will drain, including the top hose and the top of the radiator.
I just siphoned off a gallon or so. Probably way more than you need. Less mess, save the environment, yada yada yada...
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
Uhhh no. Not that much. Just have the end of the upper hose up in the air so none comes out after the initial take off and change the stat when the engine is completely cold.
01bonneSC
89 SkiDoo
Post by 01bonneSC »
These are also an option
RJolly87
Post by RJolly87 »
I am not so sure on that, because as soon as you pop the thermostat out, it will just drain through the engine, right?
01bonneSC
89 SkiDoo
Post by 01bonneSC »
Im just going by what happened when I did mine twice. Coolant loss was a minimal, about a pint, no where near a half gallon.
If its that big of a deal, just pop the petcock and catch the fluid or siphon it out of the radiator with a hose.
Ludichris
Year and Trim: 2005 SE
Post by Ludichris »
01bonneSC wrote:Im just going by what happened when I did mine twice. Coolant loss was a minimal, about a pint, no where near a half gallon.
Yeah, I just did mine a few weeks ago, and I was in a MAD HURRY, had to get it done ASAP so I could get on a 200 mile road trip. I hadn't ever done it before, and like someone said above, if you hold the radiator hose up in the air after it comes off, coolant loss will be minimal indeed - and I didn't have a different car to drive, so I did mine HOT. Not that much coolant loss at all. .
My 4th Bonnie...I love these cars!
wader2k
Post by wader2k »
Love the vise grips!
Last 2 cars I changed thermostats on there was no problem with coolant loss... no biggy though I'll just wade in and make a mess.
Just make sure none of the neighborhood dogs hit your garage...
01bonneSC
89 SkiDoo
Post by 01bonneSC »
00Beast wrote:Just make sure none of the neighborhood dogs hit your garage...
:withstupid:
Any messes I do make, I clean up. A drain tub under the engine/trans works.
wader2k
Post by wader2k »
I forgot to ask....will I need to reset the code after replacing the thermostat or will it reset itself after a short time driving?
It should reset itself once the condition is solved, and like 40 some key cycles to clear it from your history.
