MAP/MAF DTCs - sensing engine torque problem
Posted: Fri Nov 23, 2012 11:20 am
Have a 99 Bonneville Se with 163000 miles on it. Recently had DTC light, after problems with Overdrive Lockup torque-converter doing the 'shudder' on a very slight incline of highway at 65MPH with CrusieControl engaged. Otherwise the car had been driving fine.
Fuel-pressure was found to be low; i.e. - engine had not been making enough torque for the transaxle Computer-controller to be able to correctly tell it WHEN to shift; it had not been getting sensor information that was within it's Factory 'map' of program-code, we figure.
Replaced the fuel-pressure regulator, and car was then driving normally again, shifting in and out of Lock-Up on the Highway correctly, and on back roads at lower speeds was also shifting into lower gears (from OD) for hills, automatically.
All was wonderful...until we drove it 107 miles. Then got the Check Engine light on dash again. DTCs were pulled at Autozone:
P0102 - MAF - Circuit A voltage low
P1106 - MAP- (*different DTC than previously) - "Engine operating within Failure Mode Test conditions and the ECM detected the MAP sensor voltage was above 4.8 volts".
*Note that these are Autozone-generated blurbs about the codes, NOT directly from G.M./FSM.
The MAP blurb implies that the engine is operating in a Failure Mode. Anyone with GM technician experience or with a GM FSM, know exactly what that might be?
*I DID perform an "Emissions Test Readiness Monitor" drive-cycle specifically, earlier, after work was completed on the car and the battery was re-connected. [ "With fully warmed engine, from a stop, accelerate to 50-to-55MPH using 1/2 to 3/4 throttle, and hold that speed steady for 5 or 6 minutes, have rear defroster "ON" if equipped. After above conditions are met, stop quickly (use caution re other drivers behind you), then accelerate again as above, to 55MPH..then coast, to below 20MPH, foot off brake and throttle (manual trans cars placed into neutral)". ]
I am guessing that the engine is either still not making (just) enough torque, to generate MAF and MAP sensor signals that are within the range which the computer program code is able to use successfully...or...one of the sensors actually IS faulty at the specific difficult detecting conditions
(engine at 1600 RPM, car at 65 MPH, trans in OD/Lockup, reaching a very slight highway incline).
Any thoughts?? Any technical information for me re either MAF or MAP sensor?? (Both WERE cleaned, carefully and correctly, when we did the other work.) Both are WORKING just fine during ALL other driving conditions. I am not going to just go out and buy new non-returnable Sensors without a VERY good technical/proven reason for doing so.
