1997 Bonneville won't start. Windows and locks don't work
97beigebonny
- LE Member
- Year and Trim: 1997 Bonneville SE
My daughter started her 1997 Bonneville SE yesterday morning upon which it stopped running. When she tried to restart it, it would crank but not start. Also, the windows and door locks would not work and the rear defrost light would come on when the door was opened. The car has a new battery and the terminals are clean. I drove to her apartment that evening and found the car was doing the same as described. I decided to disconnect the battery and reconnect it to see if that would do anything. The car started and the windows, locks, and rear defrost button all worked. My concern is having this happen again. Any ideas on what may be causing this would be appreciated.
- J Wikoff
- Year and Trim: 1992 SSE
Re: 1997 Bonneville won't start. Windows and locks don't wo
The battery cables might have been just a bit loose.
But you could look at the ground busses under the a-pillars, and the fues panels for corrosion.
- Mechanical Mike
- Retired Gearhead
- Year and Trim: 99 SSEi
Driver's side ground bus. Windows, locks & fuel pump are a few of the things that share that ground. They get wet & corrode - common problem.
Last edited by Mechanical Mike on Sun Sep 30, 2012 12:20 pm, edited 1 time in total.
2006 Chevy Monte Carlo SS
- 3800SERIESII
- Posts like an LG3
- Year and Trim: 1999 Pontiac Bonneville SE
1997 Pontiac Firebird
for sure the bus ground on the drivers side. Had the SAME problem not too long ago. Used a toothbrush and baking soda, put some wd 40 to prevent moisture and I just keep it hung out of the carpet so if there are anymore problems, it is a quick fix. Windows, locks and fuel pump run off of it. That is why it cranks and doesnt start.
1999 Pontiac Bonneville SE- Stored -All stock, Sony CDX-GT570UP HU w/ Scosche HD 6.5"'s front/Alpine S 6x9 rear, 153,000 miles
1996 Pontiac Bonneville SE- Now a parts car - HAI, Muffler Delete, Summit Y-pipe, 250,000 miles
1997 Pontiac Firebird - DD - 3800 Series II, Cold air intake/FWI, Y87 Package, Sony DSX-S100 Digital Media Reciever, 180,000 miles
97beigebonny
- LE Member
I appreciate your help. Could you tell me where the drivers side ground bus is located?
- Mechanical Mike
- Retired Gearhead
97beigebonny
- LE Member
Going to check it tomorrow when I can get over there. Will let you know what happens. Thanks!
97beigebonny
- LE Member
Car would not start when I got to it today. Cleaned the bus ground on the drivers side as you recommended and the car is starting right up. Thanks again.
- 3800SERIESII
- Posts like an LG3
That is great news. That always works like a charm.
