Gxp exhaust
MikeGM24
Year and Trim: 2004 GXP
Gxp exhaust
Post by MikeGM24 »
Is there any othe performance exhaust besides flowmaster that will sound great and have a nice rumble for my gxp??
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Re: Gxp exhaust
Post by 01bonneSC »
Magnaflow and Gibson are less raspy in my opinion.
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Re: Gxp exhaust
Post by repinS »
Corsa.
My post from another thread ( http://www.pontiacbonnevilleclub.com/fo ... 35516.html )
I'm pretty certain that any solution you put will sound good. It's hard to mess that up on a Northstar. The question becomes - how much drone will you have and how much you can handle.
On the cheap end you can get good sound but will have drone - on occasion you will get lucky with your piping/muffler combination and it'll work out to be quiet. If you want to drop four figures on a new Corsa system (Part number 14151), it'll scream like nothing else and be drone-free and quiet when you're not pushing it. Construction wise they are straight-through but Corsa works some sort of magic to eliminate drone. They also add another muffler/resonator right after the cat. Many here have seen this before: http://www.youtube.com/watch?v=YlKgtt8jlWc&t=45s&hd=1
maroon111993
Year and Trim: 1997 Grand Prix GTP
Re: Gxp exhaust
Post by maroon111993 »
BORLA!
(If you have quite a chunk of change)
1997 Grand Prix GTP "Black Ice, 'cuz it's slick" - 17" Motegi Racing Rims, Hankook Optimo Performance Tires, 'Big 3' Wiring Upgrade, Weapon R Secret Weapon Intake w/ Ram Air, Larger SuperCharger lines, AutoLite 104's, U-Bend Delete, Resonator Delete, Cat Delete, Turbo Flowmaster Mufflers. 342bhp, 327 lb-ft torque, 9.091 boost psi @ 6,012 rpm.
Re: Gxp exhaust
The Corsa is the most awesome in my opinion, however it is rather expensive. You really can't make the Northstar sound bad. Flowmasters will be the most throaty. But Magnaflows will sound amazing too. See here:
http://www.youtube.com/watch?v=QZ9hxPokpt0
sethjamesrimrodt
Re: Gxp exhaust
Post by sethjamesrimrodt »
I think I like the Flowmasters, but I drive 75 a lot..
Seth
Re: Gxp exhaust
The only "catback" you'll find is the Corsa, and that requires a little modification. Everything else is going to be buying mufflers and having them welded in.
andrewsowinski21
Year and Trim: 2002 bonneville ssei
Re: Gxp exhaust
Post by andrewsowinski21 »
corsa off a sts works with some mods
SSEiMan01
Re: Gxp exhaust
Post by SSEiMan01 »
nos4blood70 wrote:The Corsa is the most awesome in my opinion, however it is rather expensive. You really can't make the Northstar sound bad. Flowmasters will be the most throaty. But Magnaflows will sound amazing too. See here:
:withstupid:
I'm a Flowmaster guy myself... But regardless of brand N*+Aftermarket exhaust... Dat sound!!! :)
James May wrote:Hello.
05boni
Year and Trim: 2005 boneville gxp
Re: Gxp exhaust
Post by 05boni »
Hi guys just installed magnaflow and it sounds awesome. BUT the inside of my car sounds like I'm
In a subwoofer box. I had no idea it would be so loud inside. Anyone else have the same outcome?
sethjamesrimrodt
Re: Gxp exhaust
You should take a video of many different rpms for us. And what model of flowmasters?
Seth
05boni
Re: Gxp exhaust
Post by 05boni »
I will try but all I have is my iPhone, my computer is down.
sethjamesrimrodt
Re: Gxp exhaust
You can put it on YouTube from your phone and link it here if you have wifi
Seth
Re: Gxp exhaust
He has Magnaflows Seth.
I get drone at certain RPM's.
05boni
Re: Gxp exhaust
Post by 05boni »
I know others have done because I've seen the you tube videos. I was hoping for there input on how bad it echoed inside the cabin. This is also my first V8 with aftermarket exhaust, so maybe it's just me.
sethjamesrimrodt
Re: Gxp exhaust
Wow I'm bad at paying attention today
Seth
CMNTMXR57
Re: Gxp exhaust
Post by CMNTMXR57 »
Mine was Magnaflow and I have mine out on Youtube (which is what you probably watched).
Borla, in general sounds like someone rattling a bunch of rocks in a tin can. Flowmaster only sounds good on old school BBC's, SBC's and 5.0's. Just my opinion. It does not reflect those of management.
I prefer DynoMax or Magnaflow personally. I used two Magnaflow 12225 mufflers (2.25"), and 2 35121 tips, and two appox 1ft sections of 2.25" stainless that I bent to roughly 30* angles (not exact, just saying that as a description), to bring it back out the back of the car properly.
The only complaints I have with Magnaflow;
1) It left a bit of drone around 75mph. I could tolerate it, but the Wife hated it when she would be in the car
2) I would paint the Magnaflow's, or they will look like this after awhile (these are on my GXP);
It is a perfectly normal process of the metal protecting itself. It is NOT rusting through. It just looks bad. So to counter, I would go sand/grind it down, and apply a high temp silver paint. I do this on all my Magnaflow cars now, including the Bonneville, the Caddy, Jovan's Bonneville, etc...
I do not have any after painted pics other than my STS;
2011 Camaro SS
05boni
Re: Gxp exhaust
Post by 05boni »
I'm pretty sure your car is the one I saw on YouTube.My drone is pretty much every time I hit the gas but I have to go back to the muffler shop tomorrow to get one of my tips installed because they ordered the wrong one so hopefully that will help out the Noise inside the car. If that does not work I may have to put some insulation under the trunk. By the way my magnaflow's are stainless are yours?
CMNTMXR57
Re: Gxp exhaust
Post by CMNTMXR57 »
Just the regular stainless. Not paying for the high polish ones, that will look the same after 6 months, resulting in me having to paint them just the same.
2011 Camaro SS
repinS
Moderator
Moderator
Re: Gxp exhaust
Post by repinS »
As said before, zero drone with the Corsas. Stock sounding on the highway, a bit of noise on light acceleration, and full out screamer when you get on it. Tips may have an effect, but I think the type of muffler is the issue at hand here. You may have improved (or even worse) drone with different models of Magnaflow. Pipe bends, diameter, and length also have an effect, did you touch anything there?
The GXP does not have a muffler/resonator right just behind the cat when stock, but the Corsa system adds one on top of the two at the back. If you have the resources to play around with your setup, that may be another option to tune out certain frequencies that cause drone.
