Anyone know if this is supposed to be a drain? Because i can pour water on the hole and it comes out below.
Padding under the carpet was absolutely sopping wet. I ran the air for a while and that did not appear to be leaking inside. I also poured water in the sunroof and it appeared to be draining normally. From what i can tell, it is isolated to this one area.
