Anyone else have problems with their gas cap?
Posted: Sun Aug 26, 2012 4:25 pm
by keir
Mine is becoming harder and harder to take off and on with each gas station stop.It is so hard to remove that I usually end up scraping and cutting the skin on my thumb knuckle as I try to turn the cap....
Re: Anyone else have problems with their gas cap?
Posted: Sun Aug 26, 2012 6:03 pm
by 01bonneSC
Is there a bunch of rust around the filler tube? That's probably what is holding it on.
Posted: Sun Aug 26, 2012 6:28 pm
by keir
No there is no rust in the area.Im thinking the mechanism in the cap must be bad and I might look into a replacement cap from an auto parts store.
Posted: Sun Aug 26, 2012 6:55 pm
by harofreak00
Its not the cap, its the filler tube. I've seen this on many of my projects. I've tried multiple caps, even ones that work perfect in other cars. The filler tube plastic must expand over time or something. Replace the filler tube.
Posted: Sun Aug 26, 2012 7:47 pm
by keir
Andrew to the rescue...How do I change out the filler tube?
Posted: Mon Aug 27, 2012 10:59 am
by harofreak00
Jack up the rear, remove the wheel, remove the plastic shield, remove the 10mm ground strap, loosen the hose clamp, pry the rubber hose away from the plastic filler tube, and pull the whole filler tube assembly out the fuel tank door. It will take some muscle to wrangle it out of there.
I have a good filler tube here if you need one.
Posted: Mon Aug 27, 2012 12:18 pm
by keir
That does not sound too hard for me to take on....just get me a quote on the tube and a pair of hood lift/supports,if you have any,and we can go from there.
