I was driving to work this morning sipping my coffee and all of a sudden all the needle on all gauges (instrument cluster) on the dashboard fell to the left (as if the car were turned off). I immediately pulled over waiting for something else bad to happen but the car just kept running as normal. Not sure what the back side of the instrument cluster looks like. Could this be a loose connection somewhere or has the dashboard likely gone bad.
Suggestions ???
Thanks, Al
2005 Bonneville SLE Dashboard Gauges stopped working
homeboy517
- SE Member
- Year and Trim: 2005 SE
- Arrowhead
- Posts like an LG3
- Year and Trim: 2000 SLE
2005 GXP - Location: Frederick, Maryland
Re: 2005 Bonneville SLE Dashboard Gauges stopped working
I've had the fuel gauge become "squirrely" and the oil pressure has "pegged" at maximum psi but never heard of all of em checking out at one time! I suspect a fuse may have blown, just a guess though. Until I fix the fuel gauge, my odometer tells me when it's time to gas up!
homeboy517
- SE Member
Okay....thanks for the suggestion. Unfortunately I think the fuse for the instruments is under the rear seat...not sure what sense it made to put it there. I'll google for the manual to check for sure where it is.
- sethjamesrimrodt
- Posts like an L36
- Year and Trim: 2004 GXP
The back seat lifts up. If you put your hands at the button of the seat where the carpet and the seat meet and lift up, hard it will come up. You night even find something you didn't expect under there, like a battery. I wonder if you unplug the gauges and plug them back in of that would fix it.homeboy517 wrote:Okay....thanks for the suggestion. Unfortunately I think the fuse for the instruments is under the rear seat...not sure what sense it made to put it there. I'll google for the manual to check for sure where it is.
Seth
- drift7one
- GXP Member
- Year and Trim: 2002 Pontiac Bonneville SE
ditto here. also need to make those fixes.I've had the fuel gauge become "squirrely" and the oil pressure has "pegged" at maximum psi but never heard of all of em checking out at one time! I suspect a fuse may have blown, just a guess though. Until I fix the fuel gauge, my odometer tells me when it's time to gas up! :lol:
Side Pot: Im just curious, what kind of mileage do you get on a full tank?
drift7one
Rich- Member #6668
Golden Hurricane
| Cleared Headlights | 20% Tinted Windows | AVS VentVisors | Viper 2-Way Alarm System | Garmin GPS Navigation |
| DDM Tuning 8000k 35w HID Headlights | Nokya Hyper Yellow 2500K Fog Lights | Black PlastiDip Accents & Badges |
Rich- Member #6668
Golden Hurricane
- Arrowhead
- Posts like an LG3
I haven't calculated that in a long time, IIRC, it's around 350-400 miles per tankful. I just fill up when I hit 250 miles to be safe and not sorry.
homeboy517
- SE Member
All:
Thanks for the comments and suggestions, but alas it is not the fuse. Last night while in the middle of taking my back seat out the little lady annouces that she'd like an ice cream sundae. So, being the good doobie that I am, I offer to go get one for her. So, back seat lifted up, hadn't actually opened the fuse box yet, I start the car and the gauges are now working again. Likely loose connector (or I hate to say it, a short in some wire) somewhere.
Thanks again for all the suggestions and pix.
-Al
-Al
