I was wondering, if I adjust my AC mode to come out of the front facing vents it is cold. If I adjust my AC mode to come out of the floor or defrost vents it is warm.
Question 1 is: is this normal (I wouldn't think so but I can't remember)
Question 2 is: if not, what is the possible problem. Is it the blend door/actuator. Should I pull the rod off, set the temp to 90 and them push the rod back on?
I've got vacuum and can hear the door adjust from floor to face to defrost.
Thanks for the help.
ECC Controls - AC out the vents (Floor/Defrost)
bsan63
- GXP Member
- Year and Trim: 1998 SSE
Stone Beige Metalic 98 SSE, Clear Corners, Pretty much stock to this point.
