96 ssei brake warning light trouble
forcefedbucket96
Year and Trim: 1996 Bonneville SSEi
Post by forcefedbucket96 »
Brake warning light on dash comes on and stays on. Won't stop dinging unless I'm accelerating hard. What does this even mean? Lol.
99BonnevilleSE
Year and Trim: 1996 SSEi
Re: 96 ssei brake warning light trouble
Post by 99BonnevilleSE »
Either you're e-brake is engaged (or the sensor thinks it is), or you have some kind of brake failure. Check your brake fluid recently?
I'm backkkkkkkkkkkkkkkkk!
:withstupid:
Check the brake fluid level and pull up on the e brake while pulling the release.
gmman
Year and Trim: 96 SE
Post by gmman »
if brake fluid in master cylinder is low, check rear brake wheel cylinders for leaks.
forcefedbucket96
Yup brake fluid was low. And I do have a small leak in the rear
