water/methanol injection
deano55
Post by deano55 »
I am thinking of a water/methanol injection set up rather than a I/C on my car. Read enough about innercoolers so would like some info from ones that are running w/m injection. I know theres a few on hefe so dont be shy about answering.
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Re: water/methanol injection
Post by 01bonneSC »
Theres a few threads on it. A search should get ya going in the right direction.
yourgrandma
Year and Trim: '02 SSEi
Post by yourgrandma »
Not a whole lot of 3800 people run it, but it does work. I think the main drawback is that you can't place the nozzles the optimum distance from the intake ports after the supercharger. The methanol strips the coating off the rotors, so a post blower spray is best. I've seen nozzles in the ends of the lim.
I've even been putting some thought into it lately with as big a pain as its been to get the intercooler set up.
sandrock
Post by sandrock »
Here's my thought on how to run the setup....
1) Take intake manifold, drill hole right under the MAP/boost control/fuel pressure regulator port. It'll be at the front (accessory) side of the mani.
2) Tap said hole....giggity.
3) Run a metal tube lengthways inside the mani. Terminate with a "y", with a fogger nozzle on each branch.
4) Connect the supply tube.
It works in my mind. But my mind tends to be...unreliable.
deano55
Post by deano55 »
Oh, didnt know its hard on the coating? I just am not likeing the heater core idea under my super charger. I have been talking to Intense amd they say testing shows a fair amount of restriction, so then a pulley size drop is done to make up the difference in prressure/boost drop, no you end up with the same heat you had before.
yourgrandma
An intercooler does present a restriction but the cooling of the charge air far outweighs that restriction. I've never heard of anyone not gaining power with a proper intercooler.
The tube and branch fogger setup could work, but id be afraid of having that in the manifold waiting to come apart or somehow become misaimed. Also, the water/meth mixture needs time to absorb heat (the whole point of the system), so putting the nozzles at either end of the plenum will fill the whole plenum with the mist and hopefully absorb as much heat as possible.
deano55
Post by deano55 »
I think Intense was saying you have to pulley down one size to get the flow you had before you had the intercooler?
GMC Guy
Year and Trim: 1999 Bonneville SSEi
Post by GMC Guy »
If i remember right 2000silverbullet has TONS of experience on this kind of setup.....((((((((((silverbullet where are you?))))))))
Tinted 13% Front 3% Rear, MSD Coils and Wires, K&N drop in air and oil filter...more to come as things wear/break!!
Tint it so dark, you won't even know your name
The two main supports of this are no longer on the forum. 2000Silverbullet is banned, and willwren has stepped away.
01bonneSC
89 SkiDoo
Post by 01bonneSC »
harofreak00 wrote:2000Silverbullet is banned,
:eek2:
deano55
Post by deano55 »
:eek2:
Lol :bluetwitch:
01bonneSC
89 SkiDoo
Post by 01bonneSC »
I musta missed something that was behind the scenes but back on topic.....
Also the W/M injection bottle is only like 2gal(?). So pretty limited on use.
IIRC Paul's was 2 quarts, at least his first one. Good for a half a dozen passes, or 20 minutes of spirited driving, IIRC.
The diesel guys run as big as 7 gallons, but that's gonna eat up trunk space...
01bonneSC
89 SkiDoo
Post by 01bonneSC »
00Beast wrote:IIRC Paul's was 2 quarts, at least his first one. Good for a half a dozen passes, or 20 minutes of spirited driving, IIRC.
qts, thats right. Thats even worse than I thought lol
yourgrandma
Use the washer fluid res.
IIRC Paul was rigging that up. He rigged another pump up to refill his reservoir for the W/M, so he could keep the washer function. Just don't use the winter blend or "bug remover" stuff in the windshield washer res...
Sadden
1994 Bonneville SSEI
2006 Grand Prix GXP
Post by Sadden »
[quote="harofreak00"]2000Silverbullet is bannedquote]
Wtf?
When did this happen?!?
Basically will said that he felt that it was there to cover up an inherent issue , that being heat. Its a band aide to a flow related problem. An intercooler is a more reliable solution that does not need to be refilled....
2kSB , used his everyday , (probably filled it everyday too LOL) , and he did use it to allow him to pulley down. IDRC how he had it plumbed though. It worked reliably for him though.
yourgrandma
I would think you could easily have it gravity feed into the res. You'd keep the washer function and the low level warning light.
Its not uncommon at all to use meth injection on a daily driver. If you use either a boost switch or a wot switch, how often would it actually kick in? Personally I wouldn't totally rely on it though. Id rather have it there as an option in hotter weather or if I want to pop on a smaller pulley to suck more babies into my blower.
Paul's car was a "toy", he had like 40k on it in 10 years. IIRC he drove his Firebird more often....
sethjamesrimrodt
Year and Trim: 2004 GXP
Post by sethjamesrimrodt »
Sadden wrote:
harofreak00 wrote:2000Silverbullet is bannedquote]
Wtf?
I agree with it being a 'band aide'
Seth
