Chirp/warble "ree-ree-ree" sound from driver's front wheel
Posted: Sat May 26, 2012 8:47 am
So when I bought the SE, I had to have the front passenger wheel hub bearing replaced, so I am familiar with the “groan” or “howl” sound associated with that.
Recently, in the last few weeks, not long after I replaced the front pads and rotors, there has developed a definitely metallic chirping or warbling sound when the front driver’s wheel (I am 90% sure it is the driver side) is rotating. It is more a “ree-ree-ree” than “wah-wah-wah”.
It starts a few minutes after beginning driving if the car has sat for more than a half hour or so. It continues at nearly all speeds, from 20 mph in town to highway speeds. If I turn to the right it gets a little more pronounced, if I turn to the left even slightly (like a lane change or a slight adjustment) it stops.
The odd thing is (as if this is not odd enough), it goes away when I begin to accelerate even slightly, and goes away when I begin to brake. Even tapping on the pedal with no discernible braking power applied…it goes away. Then resumes when the car is “coasting” or under normal load.
Now I also know that I have camber wear, on both front tires, so I today when I am changing the oil I will be investigating the control arm bushings and the ball joints and taking a look at the calipers in case there is something rubbing.
Any thoughts?
Thanks, all!
Any thoughts?
Thanks, all!
