'95 SSEi, what is the best code reader?
Ingo0123
Year and Trim: 1995 Pontiac Bonneville SSEi
Post by Ingo0123 »
I have a '95 SSEi that can't establish a connection to the reader. The check engine light came on a few weeks ago and its intermittent with rough idle. As soon as the car starts idling rough the check engine light comes on. When it starts running smooth, it goes off. I assume it is either the MAF or O2 sensor. Couldn't find any posts on why the reader won't connect. Anyone have any ideas?
I used more than one reader, so its not that.
J Wikoff
Re: Code reader not establishing connection
Post by J Wikoff »
Did you try a reader capable of the hybrid OBD 1.5 your car has?
Ingo0123
Post by Ingo0123 »
Thanks for the info. I believe everything hooked up to it was OBD 2. So I guess that's a place to start.
Ingo0123
Post by Ingo0123 »
So I'm a little confused. What do you guys use to diagnose your '94 and '95s? Is it an OBD1 with a 16 pin adapter? Or is it a special 1.5 reader? I also found a USB to 16 pin ALDL connector complete with diagnostic software (link below). Is this the best route to go? I really don't want to take it to a shop, I'd rather spend the money on my own diagnostic equipment. Thanks.
http://www.ebay.com/itm/GM-OBD1-Scanner ... vi-content
Whitecrystal1
Year and Trim: 10 Silverado
Re: '95 SSEi, what is the best code reader?
Post by Whitecrystal1 »
I use the Actron 9190. I'm not sure if it's the best but it's done what I needed so far, except for reading ABS codes.
2002 Buick Lesabre Custom L36 Titanium Blue Metallic/Medium Gray Cloth
2004 Buick Lesabre Custom L36 White/Graphite Gray Cloth
2015 SS Roof, Spare & 6M 6.2L LS3 415HP/415TQ SLIHRM/Jet Black Leather-Red Stitching
2010 Silverado LTZ Crew 4x4 6.2L L9H 417HP/403TQ NHT Black Granite Metallic/Ebony Leather
2013 Enclave Premium AWD 3.6L LLT White Diamond Tricoat/Cocoa Leather
2001 Wellcraft Martinique 2400 Merc 5.7L BIII 327hrs
1995 Bonneville SSE L36 Dark Polo Green Metallic **R.I.P. 4/28/10 236,400 miles**
Paintjar
Year and Trim: 1995 Bonneville SE
Post by Paintjar »
I was drawn into a 1.5 reader but it will not work with 16 pins. I guess i need the adapter. Good info here Thanks guys. Nothing with the link. Is gone.
Paintjar
Post by Paintjar »
I ran into the same problem with a 1.5 reader. There are no adapters 16 t0 12.
