turn signal/ wiper/ blinker switch replacement help needed.
- 88bonnsse
- Posts like a Northstar
- Year and Trim: 1988 sse - 80,000 on the clock and my first car...
1995 se wit da sle package- 120,000 on the clock and ticking stronger then ever... - Location: allentown pa
i am in need to change the turn signal switch on my 95, its all messed up.. i cant get the headlights to turn on unless i take 30 mins to play with the turn signal lever. and i cant get the high beams to work either.
and where the lever connects to the lil metal rod that turns on the headlights is busted...
i been looking all over and i cant find a description on how to change the lever and fix everything..
i cant drive the car in the night time because i can play with the swicth to get the headlights on but when its time to come back home they most likely wont work.
can anybody tell me how to do this ? and i hope i dont need to change the steering comumn..
- Backhoe
- Posts like an L27
- Year and Trim: '98 LSS L67
Re: turn signal/ wiper/ blinker switch replacement help need
Do you have a replacement lever to go back in? I'm not sure about repairing one, but removal is pretty easy, If it's like my 98, you remove the little box cover under the lever, dis-connect the clip, and pull the lever straight out of the column.
I think the turn signal switch is a bit more involved, as i believe you have to access the interior of the column, but I'm sure someone else more knowledgeable than myself will have the info you need. I'll check my FSM when I get to work today, now I'm curious to know myself.
1998 Olds LSS/L67, 92K miles, Intense FWI, SSAC headers, 3.2 MPS, cat delete, 180 stat, AL 103's, HPT.
1996 Olds Eighty Eight LS/L36, 146K miles, mostly stock
1997 Olds LSS/L36, 95K miles, raided for dent free parts and sold
1989 Bonneville LE Gem (sold)
1987 Bonneville LE (retired)
- 88bonnsse
its not really the lever. its the things the lever connects to.. ill get detailed pics shortly..
- Backhoe
- Posts like an L27
Unfortunately it sounds as if yours is a fair bit different than mine, my light controls (manual) are on the end of my dash, not in the column, even tho the Bonnie is covered in this manual. I'm still learning how to use this book, but from what I see, you're going to need some reference materials if you attempt this.
Hopefully somebody can provide some details for your car, since it will most likely involve wheel/column removal, and there is a TON of stuff crammed in there. The air bag also needs to be disabled if you have it.
Have you sourced the part yet? I'm betting the old one may be done for, they take a shoot load of abuse sometimes.
This one I think,
http://www.ebay.com/itm/ACDELCO-OE-SERV ... 1063wt_931
A thread title specific to what you need eg: "95 columm diagram" or something might garner you some more help, sorry I couldn't help more
This one I think,
- Backhoe
- Posts like an L27
Bob Dillon
- Retired Gearhead
Check here. Very complete. I replaced a turn signal switch on my '99. You'll need a steering wheel puller (about $20 at Harbor Freight). It's tedious, but take your time and it goes well. The hardest part was getting to the plug at the base of the steering column.
DISCONNECT THE BATTERY BEFORE WORKING ON ANY AIRBAG CAR!
http://www.pontiacbonnevilleclub.com/fo ... =55&t=6944
Is it the same for a 94 se?
- 88bonnsse
instead of pulling steering wheel n dropping column. is there a safe way to wire the headlights fused with a relay directly from battery to a on off switch on my dash.. my car is coming up for inspection.
