180 degree thermostat question
Posted: Tue May 15, 2012 3:04 pm
by SSEIking
I plan to install an INTENSE 180 degree thermostat either tonight or tomorrow night. I've read a few post on here about drilling a small hole on the thermostat. I know the hole is suppose to be small. Can someone tell me how small to drill the hole and where exactly it should be? A pic would be greatly appreciated.
Thank you
02 SSEi
INTENSE FWI - NGK G-Power TR55 Plugs - 146k Miles
Re: 180 degree thermostat question
Posted: Tue May 15, 2012 3:05 pm
by 01bonneSC
1/16" hole on the flat spot just outside of where the plunger is.
Also, plan on getting your PCM tuned to have the fans come on at a lower temp to take advantage og the 180* stat
Posted: Tue May 15, 2012 3:11 pm
by SSEIking
I don't know anyone locally who will tune a PCM. Say I install it tonight and have the PCM tuned several months from now, will it hurt anything?
Louisville, KY
Posted: Tue May 15, 2012 3:20 pm
by DCJREDLINE
no
Posted: Tue May 15, 2012 3:29 pm
by 01bonneSC
No, it will be fine, just dont get worried when your temps stay where they are with a 195.
Posted: Tue May 15, 2012 3:32 pm
by Bing
Here's a good write up and a picture, pretty much explains it all. :wink:
http://www.pontiacbonnevilleclub.com/fo ... 59&start=0
Posted: Tue May 15, 2012 7:21 pm
by deano55
why dont you bleed the air of with the bleeder like it's there for? I have had many gm cars setup like this and always used the bleed off valve :dontknow:
Posted: Tue May 15, 2012 8:41 pm
by Bing
The hole helps get air past the stat so that you can get it out of the bleed valve.
Posted: Tue May 15, 2012 9:51 pm
:stupid:
Gets all the air out of the LIM and heads, etc so you can bleed it out.
Posted: Tue May 15, 2012 10:28 pm
by deano55
the 195 stat I just replaced the other day had a little something off to the side, it was a gm stat. Wonder what that was?
Posted: Tue May 15, 2012 11:15 pm
by 01bonneSC
deano55 wrote:the 195 stat I just replaced the other day had a little something off to the side, it was a gm stat. Wonder what that was?
Like this?
Same thing :wink:
Posted: Wed May 16, 2012 7:50 am
by deano55
yep thats it
Posted: Thu May 17, 2012 10:25 pm
by nos4blood70
01bonneSC wrote:No, it will be fine, just dont get worried when your temps stay where they are with a 195.
You will notice on the highway, that your temp gauge will begin to dip though.
