So I'm wondering if this is sway. The issue I'm having is while driving on hi way at about 70 mph turning right or vering if you would . I'm noticing the car kind of sway more then back almost like if the road dips the car waves a bit . Now i have tried this at all speeds and i do not really notice it at all at low speeds. I replaced the wheel bearings recent and did not notice anything lose or bad.
Would this be sway bar end links or something a little more serious . Any input is appreciated...
Maaybe sway bar? What do you think
JEzze
- GXP Member
- Year and Trim: 2000 quicksilver SSEI
DDM tuning HID 6000k hi/lows and fogz
FWI, 180*tstate / 18 inch enkie wraped with potenza run flats , danturs tuned pcm,
Home made motor mount / autolite 605plugs/beldin performance wires. Hogan 3 inch dp w/ magnaflow hiflo cat, zzp plot and 3.4 smoothflow MpS, trans go shift kit, 10 inch gtablet mounted running torque app.
I have a kr issue please help....
JEzze
- GXP Member
Re: Maaybe sway bar? What do you think
Seams to be only when veering to right at or about 65_70 mph.
Just seams like it will turn with the wheel then if there is a hump in road it will just turn just a bit more like swerve..... ANY ideas is appreciated.
01bonneSC
Have you had your alignment checked recently?
Mark Fahey
- Posts like an LN3
- Year and Trim: 2000 SSEi, 3.4", FWI, Saner HD sway bars,137K
Check to see if the links are broken. My fronts were broken due to age and corrosion.
JEzze
- GXP Member
No I ha even not, the stering is dead straight.. Just on a long rt turn at high speed I can feel the car swerve a tiny bit...01bonneSC wrote:Have you had your alignment checked recently?
- J Wikoff
- Year and Trim: 1992 SSE
I was going to suggest the alignment too. Sounds "toed-out" a bit.
