i need some advice
Posted: Sun Mar 04, 2012 12:53 pm
by JEzze
OK my mods are listed below. My question is I am understanding that with the sc pulley smaller the better with supporting mods. With what I have what's the best pulley. I have 3.4 3.5.
I'm getting a plog really quick but for now I understand I can get more power with the bigger pulley. Can someone please explain. Thanks in advance.....
Re: i need some advice
Posted: Sun Mar 04, 2012 1:46 pm
by yourgrandma
Looks like youre in 3.6-3.5" territory with stock timing. If youre running KR free, tuning in more timing and better fueling would theoretically be more beneficial than adding boost.
Posted: Sun Mar 04, 2012 4:55 pm
by JEzze
So more fuel and timing is the trick.. I see I have speed daddy's. I have found some decent headers on eBay was wondering if it's really worth the extra hundo far headrs over plog. I also I'm getting 3* kr with 3.4, I was going to just do plog until I checked eBay headders...
Posted: Sun Mar 04, 2012 4:59 pm
by yourgrandma
Headers are definately the way to go.
There are differing opinions about timing vs boost, my view is that more timing is safer and more efficient.
Posted: Sun Mar 04, 2012 9:20 pm
by wake
yourgrandma wrote:there are differing opinions about timing vs boost, my view is that more timing is safer and more efficient.
i agree
OP, IMO id put your headers on first, check for KR and if you have none then drop to a 3.5 pulley
3* of KR with a 3.4 pulley isnt bad but it isnt good either, ill let a gearhead explain more in detail about that!
Posted: Mon Mar 05, 2012 12:16 am
by JEzze
Any gear head interested in lighting me on the best all around move . I have searched an searched here an GM forum there seams to be a lot of discussion. With my location and weather I just want of course the best set up and safe .
Posted: Mon Mar 05, 2012 1:13 am
by BonneMe
Headers definitely are better. They have better scavenging effects AND higher flow. PEM/PLog just have higher flow, still hurt the car in the upper powerband, and need a downpipe anyways to be best effective. Why not buy headers with a downpipe and be ahead...
Posted: Mon Mar 05, 2012 1:40 am
by JEzze
Thanks for advice. I do have a hogan dp. If I was to get plog do I need to get crossover as well
Posted: Mon Mar 05, 2012 2:21 am
by yourgrandma
Get the headers, keep scanning. If I had it to do again, id probably have wrapped my headers. It does shorten their lifespan a bit, but for the price of ceramic coated togs or slps, I could rot out 3 or 4 sets of speed daddy's.
As for the pulley, on my setup, even with a big honking intercooler, I plan to keep my 3.4" and go for 18+ degrees of advance at WOT. Idea being that it will allow the pcm to pull that ecra timing if theres a problem. It also puts less paracitic drag on the engine and heats my charge air less.
Posted: Mon Mar 05, 2012 5:18 am
by JEzze
That's interesting. So as far as the timing go how to I now what is normaland if I'm getting timing advance. It seams like the timing is all over the place. Starting at 0 when I start it and it walks it way up to hi 30 . So the higher the numeric for timing the better
EDIT * WHERE'S THE BEST PLACE TO GET THE SPEED DADDYS
Posted: Mon Mar 19, 2012 2:33 pm
You want to know the timing at Wide Open Throttle (WOT). That's really all that matters for you.
Posted: Mon Mar 19, 2012 2:45 pm
by JEzze
On my way home i will check timing at wot...
