Bouncing Temp Guage?
Posted: Tue Feb 07, 2012 10:05 am
96 SSEi, 204K Miles, Ambient Air temp of between 28-38F.
So, I have noticed that my temp guage tends to move a lot. Much more than any other car I have ever had. It bounces between 195 and about 210, but sometimes will go as high as 220. Never has gone above 220. This is a relatively quick movement and can be seen and discerned with the naked eye. It does a 195-210 sweep probably 16 times in 10 minutes.
It seems to go up when I accelerate, and goes down as I let off (or upon TCC Lockup) More boost seems to create more heat and a faster increase. Fans do come on at 220. at idle it sits at about 205.
Heat works fine...very hot. Coolant levels are good, haven't lost any that i can tell in 1000 miles. Upper Radiator hose gets hard as a rock and hot to the touch after car heats up. Does still have Dex in it, I will be flushing soon.
Should the temp guage move this much, please advise, I have to drive it home from work, about 50 miles, and I don't want to damage anything further.
Thanks!
Thanks!
