Rattling door from Bass
OnlyAnSE
Year and Trim: 2001 Bonneville SE
Post by OnlyAnSE »
Hey so every time that i have my music on and the bass up a little, the window and mirror controls on my driver door seem to be loose and they start rattling very loud. is there anything i can do to tighten them or make them stop rattling when i listen to tunes?
Morgan
04 gxp bone stock internals. Touchscreen dash with heavily upgraded sounds system.
Re: Rattling door from Bass
I used two drops of superglue on top and bottom of the controls and that has held them firm and stopped the buzzing.
However, are you sure that it's the controls and not something in the door or perhaps even your tweeter?
SSEiMan01
Post by SSEiMan01 »
nos4blood70 wrote:I used two drops of superglue on top and bottom of the controls and that has held them firm and stopped the buzzing.
:withstupid: The tweeter housing LOVE to rattle, since they're held on by one clip that usually breaks when removed one time. :btruestory: I would just go over the whole door piece by piece checking for broken clips, replace what you can since superglue isn't exactly ideal for if you need to remove the panel later...
James May wrote:Hello.
That's why I only used small dollops of it. :P
SSEiMan01
Post by SSEiMan01 »
nos4blood70 wrote:That's why I only used small dollops of it. :P
I know, just making sure the OP doesn't overdo it and regret it later. :thumbleft:
OnlyAnSE
Post by OnlyAnSE »
Alright so I just took a piece of foam and fit it in behind the lock window button on the controls and it moved all the controls so that they stay in one place. works great actually although it doesnt look professional it was an easy fix so thanks for the help guys!
Morgan
KevinMcQ4367
Year and Trim: 2000 Pontiac Bonneville SE
Post by KevinMcQ4367 »
my car does that too! i just oush my leg up to the door panel by the switches when i drive.
KevinMcQ4367 wrote:my car does that too! i just oush my leg up to the door panel by the switches when i drive.
:beerchug:
That's what I have to do when I really crank the stereo on bassy songs.
