My uncle has a 98 GTP, and it has some problems with misfiring, and hard starts. Here are his codes:
P0303: Cylinder 3 Misfire
P0336: Crankshaft Position Sensor A Circuit Range/Performance
P0420: Catalyst System Efficiency Below Threshold (Bank 1)
P0440: Evaporative Emission Control System
P1404: EGR Valve
Here are my suggestions:
P0303: Checked Fuel, and spark both fine. My guess is it is caused by the CKP sensor code.
P0336: I logged it the misfire count after driving 10 minutes:
Cylinder 1: 1
Cylinder 2: 4
Cylinder 3: 2015
Cylinder 4: 400
Cylinder 5: 12
Cylinder 6: 1
I think the Crankshaft positioning sensor is causes the missing, but its really taking a toll on cylinder 3.
P0420=Clogged cat: When he bought the car, I noticed when I gave it full throttle. The rpms wouldn't go past 4k, and it stuttered and made some wierd noises. I thinking the cat it clogged nearly shut.
My Scenario: The CKP sensor went out. Thus causing these misfires. The misfires heated the cat up, thus making it kill itself.
What you guy think. Is my diagnostics right?
1998 GTP Misfiring problem, and need some troubleshooting
2000GreySSEi
- SSEi Member
- Year and Trim: 2000 Pontiac Bonneville SSEi
2000 SSEi 4th Pontiac!! 231,xxx Current mods: Gutted AirBox w/ K&N drop in. Cleared Corners. Future mods: 3.5 pulley, 180* tstat, hi flow cat, solid motor mounts, Red-Tinted Turn Signal Tails, Projector Headlights, Turn Signal Mirrors.
swampthing
Re: 1998 GTP Misfiring problem, and need some troubleshootin
I would say get the crank sensor changed first and see what the misfires do. If the cat really is plugged you should try to talk him into getting a downpipe/cat from zzp
Current fleet:
Current fleet:
2000GreySSEi
- SSEi Member
Yea I'm definetly going to tell him about that.
First replace the cat. Then look at the misfires, and check the crank sensor replaced.
A ZZP DP wouldn't be a bad idea, or at the very least a u-bend delete...
