96 Bonneville Vaccuum Leak
Posted: Wed Oct 26, 2011 12:09 am
by driveway Al
Hey, need some help, I dont have any air blowing out of the vents. Only blows on defrost. I am not sure if this has anything to do with it but I did notice a broken line going to the vac. accumulator. Has anyone ever had this problem before. Thanks.
Driveway Al
Re: 96 Bonneville Vaccuum Leak
Posted: Wed Oct 26, 2011 12:11 am
by J Wikoff
That is likely the exact problem. That vacuum reservior on the firewall (or where ever it is on a 96) is where the HVAC gets its vacuum supply to move the air diverter. The flap defaults to the defrost/floor position when there's no vacuum present.
Posted: Wed Oct 26, 2011 3:59 am
by impala67
there is good tips about fixing these on how-tos. might be a good time to clean the core while at it, its done usually from engine bay side, and cleaning it helps the amount of blow also. heater cores get really dirty since we dont have any fresh-air-filter in front of it to collect the debris.
Posted: Wed Oct 26, 2011 7:31 am
by willwren
Isn't the vac accumulator in the fender on a 96? Not on the firewall like a 95 and older?
Evap cleaning is in Techinfo.
Posted: Wed Oct 26, 2011 9:36 am
by J Wikoff
Maybe? I don't know.
Posted: Wed Oct 26, 2011 10:51 am
by gmman
96 vacuum tank is under passenger front fender below headlight.
Posted: Thu Nov 03, 2011 3:37 pm
by psburtis
hey, i have the same problem with my 96. driveway, could i get some pics of the area i need to look at once you've fixed the problem?? that would help a lot.... thanks!
Posted: Thu Dec 15, 2011 1:42 pm
by psburtis
hey, is this the problem i'm looking at right here? if so, how do i fix it?
