Poly/Energy Suspinsion Endlinks 2000+ ?
- Hans
- Year and Trim: '07 MDX | '13 TL | '06 GTO
What part numbers do I need? There used to be a good writeup on the old Bonneville Club, but I cannot seem to find a thread about it. What part numbers do I need for the font and rear on an 00?
CaliSSEi
- LE Member
- Year and Trim: 2001 SSEi Sold. Thinking about a 2005 GXP
Re: Poly/Energy Suspinsion Endlinks 2000+ ?
I'd also like to know. The bar bushings are not the generic "D" shape like so many others. And the end-links seem to have a very large diameter spacer rather than a simple tube with a bolt through it. No luck on Energy Suspension or Prothane website. Any ideas out there ?
Hard to have a killer 2001 SSEi without polyurethane (with the exception of the suspension arms).
- Archon
I believe the usual one used of the Energy Suspension is 9.8120R. Of you could buy the Moog endlinks which use the poly bushings. Frankly, I was unimpressed with the difference when I installed the Energy Suspension endlinks.
01bonneSC
I got the Moog units from RockAuto.com. Don't forget the club discount!!!
- DCJREDLINE
- Posts like an LN3
- Year and Trim: None
Dunno if the SE is a diff endlink but I got the HD Moogs for $9.99 each from Advance Auto.
2004 Saturn Ion 3 Quad Coupe
freneticburn
- Posts like an LN3
- Year and Trim: 1998 Bonneville SE?
That probably depends on how worn the originals are. I know on my car it made a world of difference but my originals were looking pretty used up.Archon wrote:I believe the usual one used of the Energy Suspension is 9.8120R. Of you could buy the Moog endlinks which use the poly bushings. Frankly, I was unimpressed with the difference when I installed the Energy Suspension endlinks.
