Code: P0440?
Code: P0440?
P0440: Evaporative Emission Control System Malfunction.
Not quite sure where to start with this one (I do know the EVAP system). I have as of 3 months ago replaced all the rubber lines for the EVAP system.
I did not see any that have become unplugged or loose.
Which of the 3 should I look into as the culprit for this code: vent solenoid, charcoal canister, purge solenoid, or even any of these?
I'm up for suggestions, thanks guys.
dangrus4060
- GXP Member
- Year and Trim: NEW 99SSEi
Daughter-97SEw/SLE Opt
98SSEi Wrecked - Location: Winston-Salem, NC
Re: Code: P0440?
I'm interested in the responses for this one also.
I have the same code show up about every other fill-up...MIL light somes on at about 1/2 to 1/4 tank and when I remove the gas cap to fill up, TONS of air somes out. I reset the light, then 2 tank fills later, do it all over again.
Been doing this for about 6 months now.
Dangrus4060
99 SSEi Galaxy Silver w/Dark Pewter Leather, Bought Aug. '08 w/75,000 mi. Bose Sunroof Michelins 35% Charcoal Tint(max. legal) Gutted Airbox w/K&N Drop-in 180Deg. Drilled Stat. Flushed Dex-Col Castrol Edge 10W30 w/PureOne Dual Chromed-Stainless Exhaust Tips Avital - Avistart 5303 Remote Start w/Security SilverStar Ultra's HL Rebuilt Motor w/New Crank & L32 Powdered Metal Connecting Rods
Daughter's 97 SE w/SLE White w/Dark Pewter Leather Bought Apr '06 w/153,000 mi. AM/FM/CD w/ 7-Band EQ Gutted Airbox w/K&N Drop-in
180Deg. Drilled Stat. Flushed Dex-Col Valvoline Max Life 10W40 w/Pure One Avital - Avistart 4300 Remote Start w/Security
Re: Code: P0440?
Slight update, after resetting the aforementioned code it has not reappeared.
Was this just a fluke?
Just seems weird that the whole EVAP system would just malfunction.
- reb
- Posts like an LG3
- Year and Trim: 1997 Bonneville SE 40th Ann Edition
Original Owner - Location: Wantagh, NY
Re: Code: P0440?
Are you sure its not air going in?dangrus4060 wrote:I'm interested in the responses for this one also.
You could have a vacuum drawn on your gas tank.
Any metallic thumping noise from gas tank?
Possibly your fuel tank pressure sensor is malfunctioning.
THE FUEL TANK PRESSURE SENSORS ARE UNUSUALLY SUSCEPTIBLE TO MALFUNCTIONS. IF THE SENSOR MALFUNCTIONS, EXCESSIVE VACUUM CAN BE APPLIED DURING SELF-DIAGNOSTIC TESTING.
dangrus4060
- GXP Member
Re: Code: P0440?
Nope, definitely air PRESSURE...I can feel the air rushing past my hand as I undo the cap along with an immediate strong smell of gas vapors...and sometimes droplets of gas accompany it...wouldn't be doing that if it was vacuum...and I think if it was THAT MUCH vacuum in the tank, it would collapse.
Dangrus4060
- dpnewfie
- Posts like an LN3
- Year and Trim: 2005 GXP
Re: Code: P0440?
How long since you cleared the code? My experience with this tells me it will come back. I've been dealing with this same issue for some time now. Just haven't had time to investigate.Bing wrote:Slight update, after resetting the aforementioned code it has not reappeared.
Was this just a fluke?![]()
2005 Bonneville GXP, 200k and SOLD!J Wikoff wrote:It has been an honor and privilage to have been serviced by you.
- reb
- Posts like an LG3
Re: Code: P0440?
It appears your Evap system is not purging the fuel vapor collected from the gas tank. You need to check the vent line from the gas tank to the charcoal canister for free flow. Plus check that the purge and vent solenoid/valves are working properly. When you remove the gas cap, fuel vapor is escaping that is supposed to be stored and then burned in the engine.dangrus4060 wrote:Nope, definitely air PRESSURE...I can feel the air rushing past my hand as I undo the cap along with an immediate strong smell of gas vapors...and sometimes droplets of gas accompany it...wouldn't be doing that if it was vacuum...and I think if it was THAT MUCH vacuum in the tank, it would collapse.
Re: Code: P0440?
About a week now, so far so good.
mastersj
- SE Member
- Year and Trim: Stock 1997 SSEi, White with Sadle interior.
Re: Code: P0440?
My 97 SSEi is doing the same thing with the air pressure escaping when opening the fuel cap.
Does anyone have the schematics for the Evap system or where I should look for the problems.
- renchjeep
- Posts like an LG3
- Year and Trim: 1994 Bonneville SE 240k Hot Rod
Re: Code: P0440?
I would go for the purge solenoid first. Haven't had mine go bad, but the Crown Vic Police Interceptors I work on every day have had the same symptoms/codes, and the purge solenoid is the problem 99% of the time. Not the same car, but it's all OBD2. Very similar systems.Bing wrote:P0440: Evaporative Emission Control System Malfunction.
mastersj
- SE Member
Re: Code: P0440?
There are no codes being generated with my issue- Just huge amounts of pressure when opening the cap.
I have started leaving the cap slightly loose as in Fla it gets hot out- Don't need any KABOOMS
- Wes
- Posts like a Northstar
- Year and Trim: 2002 Buick Park Ave
Re: Code: P0440?
The most common resolution I see for people with this code is the gas cap. The rubber seals on the cap get dried out and cause the tank to lose the seal. This doesnt sound like your problem if you hear that much vacuum when you open your cap. I agree with checking the purge solenoid.
The reason why this code comes back after a while is because it is an intermittent test. The pcm will do a pressure check on the system every 1k miles or w/e interval is set. So when you clear the code w/o fixing it it will take some time before seeing it again.
Mastersj, I dont know how you dont trip a code if you leave the cap loose. Have you noticed your mileage decrease since doing this? (as you are letting you gas evaporate away)
yourgrandma wrote:High
Re: Code: P0440?
Well, my issue hasn't shown it's ugly head as of yet (4 months now). As far as I know I still have the original gas cap on the car, so I'll see if it returns.
Mastersj, I think that your EVAP system is plugged somewhere in the lines, or the charcoal canister.
Just my 2 cents.
Just my 2 cents.
99-SLE
- SSEi Member
- Year and Trim: 1999 Bonne SLE
Re: Code: P0440?
Have been dealing with this one for months as well. Used to come on every time I'd get below 1/4 tank or so in the summer. Temperature changed, and it was far less common, and was gone for easily 3 months before it popped back last week along with a ineffiecent cat code. Strange.
1999 DCM SLE- COTM Jan 2012
Planned mods... FWI, Exhaust and tips,Tinted all around
She's now gone:(
viewtopic.php?f=8&t=31352&p=312104#p312104
She's now gone:(
Re: Code: P0440?
Does anyone have any info on my issue?
