Page 1 of 2
cold airintake system
Posted: Tue Aug 30, 2011 5:36 pm
by 93bonnevillese
i what to put a KandN cold air intake but can not find one that will fit my 93 i dont know what to do
Re: cold airintake system
Posted: Tue Aug 30, 2011 5:44 pm
by 95naSTA
Run a search.
Posted: Tue Aug 30, 2011 5:48 pm
by Bing
Your best bet is to add 3-2" holes into the air box and use a K&N filter for your car.
Heres an article from TECHINFO for your set up, lots of good stuff there for you.
http://www.pontiacbonnevilleclub.com/fo ... 80&start=0
Posted: Tue Aug 30, 2011 5:49 pm
by 93bonnevillese
found one WEAPON-R® - Secret Weapon Air Intake System
Posted: Tue Aug 30, 2011 5:55 pm
by willwren
That's garbage. Their advertising is full of lies, and the entire thing is a joke. Unless you're a ricer, then it sounds cool.
Don't waste your money on garbage marketed to import tuners. Do a search here on the Forum for "weaponR".
Posted: Tue Aug 30, 2011 5:56 pm
by Bing
NO! Please don't do that. It's a terrible design that just pulls hot engine bay air into the intake. Plus the filter they supply is CRAP!
If you want some more power, don't use anything that ISN'T isolated from the engine bay heat.
Just modify your air box like in the article or build your own Fender Well Intake.
Posted: Tue Aug 30, 2011 6:06 pm
by 93bonnevillese
found another one Universal - Airaid Cold Air Intake Airaid Ubi master kit I - With tube
Posted: Tue Aug 30, 2011 6:11 pm
by 93bonnevillese
i never new the 93s has the Mass Air Flow Sensor
Posted: Tue Aug 30, 2011 6:49 pm
by Bing
You can save yourself a butt load of money if you go with the drilled air box mod or build yourself a FWI kit.
Use this from Intense, you'll probably want at least 3'. Get some large hose clamps and a 9" K&N cone filter like the one Intense supplies with their kit.
http://intense-racing.com/Merchant2/mer ... _Induction
You'll have to get a different windshield washer fluid tank, one from a 95-99 (they are smaller). Then you can pull the charcoal canister out and the cup that holds it. This will give you the hole and route for your FWI. You can locate the Intake Air Temperature sensor in the K&N filter for ease of mounting.
This is a picture of my set up, this is a 99. You don't have to deal with the PCM, just mount the charcoal canister and some of the other details, and enjoy.
Posted: Tue Aug 30, 2011 7:50 pm
by 93bonnevillese
i found this its a universal AFE cold air intake magums force stage 1 if i iget this it will add 15 hp and 22 ft of torgue
Posted: Tue Aug 30, 2011 8:10 pm
by Bing
Post a link to the intake systems you have in mind, much easier to see what you're finding.
Posted: Tue Aug 30, 2011 8:23 pm
by wake
93bonnevillese wrote:it will add 15 hp and 22 ft of torgue
that is a complete bold face lie..there is no way to gain that much off of a intake on a L27 :eek2:
Posted: Tue Aug 30, 2011 9:23 pm
by willwren
I have to tell you that you're finding garbage and believing everything you read. That will empty your wallet and leave you wanting. Those claims are ridiculous, even for a supercharged engine.
Do you want good advice on performance intakes from people that have been using, buying, building, and testing them since 2002?
Or do you just want something that costs more than it's worth but sounds like it might be cool?
Posted: Tue Aug 30, 2011 9:54 pm
by 93bonnevillese
mines not supercharged
Posted: Tue Aug 30, 2011 10:11 pm
by 93bonnevillese
i think ill just get a Kandn air fillter
Posted: Wed Aug 31, 2011 2:01 am
by 01bonneSC
Just do this, as stated before....
And your drop in filter.
Posted: Wed Aug 31, 2011 2:45 am
by 93bonnevillese
i think i will
Posted: Wed Aug 31, 2011 8:44 am
by willwren
93bonnevillese wrote:mines not supercharged
Exactly my point.
Posted: Thu Sep 01, 2011 2:15 am
by BonneMe
NO WAY you'll gain those peak numbers. Is an intake going to reduce restrictions of the 1993 style box? Heck yes. 22lb/ft? Heck no....
FWIW My 1993 in perfect mechanical condition could spin tires easily with an Intake, and struggled without one on the same day.
Posted: Thu Sep 01, 2011 2:23 pm
by Boreas
Hey Bing, where did you get that PCM holder? That is a very elegant setup.
