service stabilty system?
- irish91983
- Posts like an L36
1992 Bonneville SSEi (Sold) - Location: burlington, mass
Hi all
Today on the way to class my service stabilty system message cam on the DIC. What does this mean? And what would cause this?
Thanks, Keith
Thanks, Keith
2001 SSEi Bumbles
Ken_W
- Posts like an L27
- Year and Trim: 2000 SSEi
Re: service stabilty system?
Are your TRAC and ABS trouble lights also lit?
Ken_W
Ken_W
- irish91983
- Posts like an L36
no neither of the abs or trac lights were or are on.
2001 SSEi Bumbles
90% likely it's your Steering Wheel Position Sensor. That's the most common culprit, but it could be a bad Yaw Sensor as well. Only way to know is to have it scanned by a dealer or someone with a high-end Snap-On scanner.
swampthing
Fwiw it doesn't affect much, I have been ignoring mine for 5+ years lol
Current fleet:
Current fleet:
- Archon
It may not in Florida, but it certainly could in Massachusetts.swampthing wrote:Fwiw it doesn't affect much, I have been ignoring mine for 5+ years lol
swampthing
mine sets cause of the SWPS, my trac and ABS work as they should.
either way the Proper thing to do is fix it right?
Current fleet:
Current fleet:
- Archon
But that won't help at all if the car goes into a sideways skid in the snow, or other conditions. The stability system is set up to make sure the car goes in the direction the steering says it should.
- irish91983
- Posts like an L36
the light hasnt come back on since I shut the car off the other day. Should I still get it scanned?
2001 SSEi Bumbles
I would. It should be stored in there.
imidazol97
- Posts like an L67
I'd check your wheel bearings for movement. I had been watching one of my front bearings for a couple years which had a small amount of play while the other bearing was tight.irish91983 wrote:Hi all
Thanks, Keith
The tire company told me one of my bearings was loose enough. They said symptoms might include the Stability System signal on my driver display. I then realized that the car would occasionally but rarely at parking speed give the Stability message when I turned the wheel to the side, which must have caused the wheel to move on the bearing and made the Stability message show up.
When I checked at home the bearing had developed a little more play, and it was probably over the .005 in spec in the FSM for lateral movement.
New Timken: message hasn't shown up since.
golfyeti
- Posts like an LG3
Every available option - Location: Winnipeg, Manitoba
FWIW my front struts are weak enough from so much mileage that any unusual combination of manouvers will set off the service stability warning - like ramping off the end of my driving and turning at the same time. I think a good wind gust from the side once set it off - lol.
Mark
The Familyman's Trans-Am
Intense 3.4 MPS, Intense FWI, Intense PCM, copper NGKs TR55's, MSD wires, MSD coils, BWD ICM, MagnaFlow High Flow Cat, drilled 180 'stat, solid front mount, Monroe Max Air rear shocks, Moog rear mounts, Moog suspension bushings, cleared front corners, 190,000 miles
02ssei
- SSEi Member
- Year and Trim: 2002 pontiac bonneville ssei
mine comes on also. it has came on from in town driving 25-30 mph and also at highway 55-60 mph. i thought it was a bearing but none of them appear to be loose. i might check into the steering next.
2002 Bonneville SSEI 170K
"Three men walking always has one teacher."
02ssei
- SSEi Member
