remote start help
remote start help
Post by gonzo4191 »
on the GTP, when i did the LIM gaskets, there is a blue wire for the remote start, its tied into the white wire on the icm (tachometer signal), where does this wire end and what should i tap it into?
kemicala
Year and Trim: 1993 SLE
Re: remote start help
Post by kemicala »
i would think it goes straight to the remote start module. or am i misunderstanding the question?
