I'm too close on this....
Locked
ohnoicuttheribboncable
Year and Trim: 2000 SSEI
Post by ohnoicuttheribboncable »
Almost got this aftermarket thing installed. It was working... until I started driving around, at which point it mysteriously turned off. Turns out that the "key on" or ignition signal that the radio needs to stay on was connected to the lighting power. This clearly is not ideal. Where can I find a signal to keep my radio on when the car is turned on? Do I need a fancy adapter from metra or another company (one that also would make my steering wheel controls work)? Thanks in advance!
swampthing
Re: I'm too close on this....
Post by swampthing »
I'm confused, lets start from the beginning, what have you installed, what harness did you use?
EDIT: we need to move to your first topic, viewtopic.php?f=13&t=27089
this is directly related and we need to keep all the info in one place
Current fleet:
Locked
