rattling in my exhaust
xvr843
Year and Trim: 1996 se
Post by xvr843 »
Like when i accelerate at times, i hear a rattle in my exhaust. i replaced the muffler and check the heat shield it still rattles
dangrus4060
Year and Trim: NEW 99SSEi
Daughter-97SEw/SLE Opt
98SSEi Wrecked
Re: rattling in my exhaust
Post by dangrus4060 »
Most likely its your catalytic converter...the honeycomb innards have come apart.
Thats what happened on both of my bonnies. Get a new one off ebay....its a lot cheaper.
Dangrus4060
99 SSEi Galaxy Silver w/Dark Pewter Leather, Bought Aug. '08 w/75,000 mi. Bose Sunroof Michelins 35% Charcoal Tint(max. legal) Gutted Airbox w/K&N Drop-in 180Deg. Drilled Stat. Flushed Dex-Col Castrol Edge 10W30 w/PureOne Dual Chromed-Stainless Exhaust Tips Avital - Avistart 5303 Remote Start w/Security SilverStar Ultra's HL Rebuilt Motor w/New Crank & L32 Powdered Metal Connecting Rods
Daughter's 97 SE w/SLE White w/Dark Pewter Leather Bought Apr '06 w/153,000 mi. AM/FM/CD w/ 7-Band EQ Gutted Airbox w/K&N Drop-in
180Deg. Drilled Stat. Flushed Dex-Col Valvoline Max Life 10W40 w/Pure One Avital - Avistart 4300 Remote Start w/Security
reb
Year and Trim: 1997 Bonneville SE 40th Ann Edition
Original Owner
Post by reb »
Try crimping the metal around the perimeter of the heat shield that covers the cat.
willwren
Post by willwren »
Jack one side of the car up (use jackstands) and kick the cat side to side and up and down.
xvr843
Post by xvr843 »
Thanks you guys, my car is stright pipe, could it be the resonator?
renchjeep
Post by renchjeep »
Could be resonator or muffler. Could also be the thin metal heat shields under the car that runs pretty much the length of the exhaust under the car, between the exhaust piping and the floorboard. The latter was the problem on my 94 SE. Look for loose bolts on the heat shield, or contact between the exhaust pipe and the heat shield. I had both problems.
sonoma_zr2
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
Post by sonoma_zr2 »
Could also be the down pipe.
The_Maniac
Year and Trim: 2004 Chevy Monte Carlo SS (L36 3800)
Post by The_Maniac »
My Monte had a problem with the resenator (more then once). I don't know if the Bonnies have them. If they do, Willwren gave you the best advice (he was referencing a CAT, but same idea applies). I got the Monte in the air and with the palm of my hand slapped the parts of the exhaust concluding with a bad resenator.
For more info about me and my cars, check out my websites below:
- 1984 Camaro Z28 5.0 Liter HO Restore Project/Big Toy
- 2004 Monte Carlo SS 3800 N/A Future daily driver
- 1994 Grand Am SE 3100 v6 Current daily with over 200,000 miles
1oldman
Post by 1oldman »
Did it start immediately after having an alignment, or any work done to the suspension, or engine/transmission mounts replaced? If so, it's a heat shield. Took two mechanics and me two years to find it. Actually, it was me crawling around under the car till I found it. - BC
xvr843
Post by xvr843 »
Started a week after i removed my cat
