Hi, I'm in the process of removing my fuel sending unit to repair the gas gauge inaccuracy. I'm following the procedure from this site found here:
http://www.pontiacbonnevilleclub.com/fo ... +fix#p2508
It seems the plastic piece of the fuel sending bucket is too large to fit through the hole in the trunk. I don't want to try to force it for fear of breaking something. Is there a trick to getting the sending unit up through the hole in the trunk floor?
removing fuel sending unit
- harofreak00
Re: removing fuel sending unit
Force. Every one that I have pulled out has been very tight. Try twisting it while pulling up, just be careful not to bend the float arm.
