tinted tailll lights
yungflash32
Year and Trim: 2002
Post by yungflash32 »
i got my tail lights tinted with the can stuff now i want it off any ways to get da spray off???????????????????????????
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Re: tinted tailll lights
Post by 01bonneSC »
Ummmm wet sand?
Did ya use VHT?
willwren
Post by willwren »
Your only chance is to wet sand it with 400, 600, 800, 1200, then clearcoat. Might be easier to replace them. Tinting tails isn't easy, especially on the 2k's.
Pretty sure WhiteArrow3800 removed his with brake cleaner and some rags.
willwren
Post by willwren »
Brake cleaner will cause most plastics to micro-crack. I wouldn't do that.
WhiteArrow3800
Post by WhiteArrow3800 »
I had a junk headlight that I tinted and tried to remove the tint. I used Lacquer Thinner and Brake Cleaner. It got rid of the tint, but it's a good thing that headlight was already junk because that stuff ate through the plastic real quick.
As mentioned, your best bet will be to sand it off or buy a new set of lights.
Last edited by WhiteArrow3800 on Fri Jun 03, 2011 8:49 pm, edited 1 time in total.
bonneville dan-o
Year and Trim: 2000 ssei
2004 GXP
Post by bonneville dan-o »
i used lacquer thinner only on my ssei to take it off. worked perfect. the used plast-x to bring the shine back.
2006 Crown Vic, white P71 interceptor. Push bar, 35% tint.
TRADED IN! 2008 G8 Ignition Orange Metallic LY7, 47k miles, Flowmasters, all options but sunroof.
SOLD! 2000 SSEI Black, 180 t-stat, autolite 104's, 3.4" MPS, custom M&D CAI, 1/8" phenolic S/C spacer, throttle body heat sheild, solid front mount, MSD wires, shift kit, 3rd brake light overlay, cleared headlights, tinted and cleared tails, 20% tint, Syntec, ARP license plate bolts Goodyear Eagle GT's,disabled DRL's, 8000k H.I.D's, pilot angel eye fogs
TRADED IN2004 GXP Black. 53,000mi.... drop in K&N filter, 5000k H.I.D. lows, 8000k H.I.D fogs, switchback 5000K turn signals. cleared headlights. 20% Tint.
willwren
Post by willwren »
That should be done with extreme caution. Lacquer thinner will also eat plastic if left too long. The best method is fine wet-sanding and polishing, then clearcoat if necessary.
