1997 SSEi Blower Motor
mastersj
- SE Member
- Year and Trim: Stock 1997 SSEi, White with Sadle interior.
Having an issue I can not solve.
3 out 4 times of driving the car the blower motor will not come on, if you leave it on after about 20minutes of driving it will start working. I have checked all the connections I can find with no luck.
ALSO when accelerating the Main vents stop blowing air and you can feel it coming out the floor vents, when you let off the gas the main vents start working again.
- willwren
- Retired Admin
- Year and Trim: .
Re: 1997 SSEi Blower Motor
Get your alternator and battery tested.
imidazol97
- Posts like an L67
Check for air flow out the defroster as the main direction with some out the heater. That indicates there's not enough vacuum and the default is being used which is defroster for safety.mastersj wrote:ALSO when accelerating the Main vents stop blowing air and you can feel it coming out the floor vents, when you let off the gas the main vents start working again.
If that's the case, look for a leaking vacuum line between the intake manifold connection next to the brake booster hose, at the plastic bottle for vacuum reserve under the fender behind the headlight, and at the connectors with the T and the one-way valve in the bundle of wires close to the accumulator for the AC under the hood. The connectors at the ends can deteriorate and leak.
mastersj
- SE Member
The vaccum hose was cracked just before entering the firewall on the passenger side- FIXED air stays on when accelerating.
Got Alternator and Battery checked- 100% no issue.
I have discovered that if the Blower does not come on after starting car opening and closing the drivers side door will usually get the blower working again.
If there anything on the drivers side that I should check ?
John
John
- Year and Trim: .
The next time it stops running or will not come on, tap the blower motor. I am suspecting you have a bad blower.
mastersj
- SE Member
I have removed the blower and checked it, checked the connector- When the blower is not working there is no voltage at the blower.
Its seems the only thing wrong with the car is the blower, knocks on wood-
For 260k + miles she runs like a top.
1oldman
mastersj wrote:I have removed the blower and checked it, checked the connector- When the blower is not working there is no voltage at the blower.
We need some pics of that car!!!!!!! - BC
sonoma_zr2
- Retired Gearhead
- Year and Trim: 1999 SSEi
Sounds like a BCM
- Attachments
[The extension jpg has been deactivated and can no longer be displayed.]
