HELP! What is this?
98buicklesabre
- Year and Trim: 98 Buick Lesabre Custom
HELP! What is this?
i have recently discovered something while changing the belt on my 98 lesabre that caught my attention on why my car feels rough and why i have the famous p0171 . its the rear fuel feed does any one know about this? i push down on it and fuel comes out is it normal? its by the 3 fuel injectors theres one in front and rear . any way to fix ? o-rings?
- willwren
- Retired Admin
- Year and Trim: .
Re: HELP! What is this?
You push down on WHAT? The little valve inside? Fuel is supposed to come out. That's the test port for the fuel pressure. If it's leaking inside the cap on it's own, use a schrader valve tool and tighten it, just like you would a valve in a tire valve stem.
You need to be more specific.
98buicklesabre
i thought the front stem was the for testing the fuel pressure..it has a rubber black top on it and when i push down on it gas does leak just wanted to know if its normal and if it could possibly trigger a code for p0171
98buicklesabre
LouderBonneville
- Year and Trim: 1998 Pontiac Bonneville SE
"rear fuel feed " did you mean where the rear fuel line plugs into the rear fuel rail ? it has like a quick relase white tabs on it like the fuel filter ?
mine would leak if i stressed the line or moved the line . i think as long as it does not leak when your not bending , moving , or pushing down on the connection then it ok and does no leak ur ok .
maybe some one else came chime in
its a connection like this ?
Last edited by LouderBonneville on Sun Apr 24, 2011 6:34 pm, edited 1 time in total.
LouderBonneville
pic does not work ?
LouderBonneville
ok yes we are talking about the same thing its a quick release fuel line connection and that clip holds it on . as long as its no leaking when your not pushing down on it its ok .98buicklesabre wrote:i thought the front stem was the for testing the fuel pressure..it has a rubber black top on it and when i push down on it gas does leak just wanted to know if its normal and if it could possibly trigger a code for p0171
LouderBonneville
98buicklesabre
LouderBonneville
does it leak if you dont touch it ? dont think there is any o rings in there but that clip can be replaced .
but when your pushing down on it your probaly breaking the seal and 50 psi of fuel is spraying out . if you dont touch it and does not leak i say your ok . maybe some one else can chime in .
to take it off just put a dry rag over the line to catch the spray , and on the first pic you see on the bottom of the clip is two arms you have to Pintch thoose two tabs inward and pull up on fuel line elbow and it will come right off . then you can inspect the clip and or replace it
Last edited by LouderBonneville on Sun Apr 24, 2011 6:53 pm, edited 1 time in total.
98buicklesabre
yeah when the car is off i push down on it and it leaks...what is the name of the clip?
LouderBonneville
does the front one does the same ? when you push on it ?
idk the name per say . i call it the fuel rail plastic retaining clip when i go to the parts store , theyy know
98buicklesabre
i dont think it did when i did it last night.....the clip has like a rubber boot on top of it ive seen it at autoparts stores vacutight but i wanna know about the clip....is this where u test the fuel pressure?
LouderBonneville
no its not where you test fuel pressure . there is a vavle like a tire vale with a cap on it nest to the fuel pressure regulator on the front fuel rail .
98buicklesabre
ohh ok so then what is the name of of part we are talking about then? thanks for the help btw
- Year and Trim: .
98 - it helps a lot if you are able to take pictures and show us what you are talking about. In 1 post, you could have had an answer. So, you are leaking where the flex line attaches to the fuel rail?
Those are fuel line retaining clips and yes there are o-rings inside the lines that seal on the metal nipple on the fuel rail. All the clip does is hold the line on. Even while running and moving them, there should not be any fuel coming out. I have never had to replace any, but I will try to find the seals / o-rings. Looks like it might be a tight place to work, if they are available without replacing the line. There should never be fuel leaking under any normal circumstance. This poses a serious fire risk.
Louder: I suggest using something along the lines of photobucket.com for image hosting. It does not take as long for the pictures to load. When I click on your pictures it takes me to the log in page instead of the larger image. Either that or the wrong link was attached.
Here is the link to the o-rings from Napa:
https://www.napaonline.com/Catalog/Cata ... cType%3aA)
Last edited by myfirstbonnie on Sun Apr 24, 2011 9:41 pm, edited 3 times in total.
98buicklesabre
Yes, i am leaking from the flex line which comes from the fire wall and goes to the fuel rail . it has a black top on it. when i push down on it fuel leaks out...thanks for the link now well i just have to snap it off the rail or is it more complicated?
- Year and Trim: .
You should be able to squeeze the clip and take it off. Be careful you do not flex the line too much.
98buicklesabre
ok, and then i replace the o-ring in it? i have a pic dont know how to upload them at the moment . new to the forum which is great
LeSabre in Buffalo
- Year and Trim: 2012 Eco
There are 2 O-rings in that clip. You'll need O-ring/seal picks to dislodge them and re-insert the new ones. You'll need 2 Viton O-rings of the right size as replacements. Regular rubber O-rings will degrade when exposed to fuel.
